Panch's 1980 LS with Rallye G60
(In Topic #203888)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/28image.jpeg)
![Panch_mk1golf in the usergroup ‘Local’ Panch_mk1golf in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I've had the car for nearly 12 years now, it started out as a 1980 1.3 golf LS model, the car was my mums prior to me having it and she bought it in 1986 so the car does have a lot of family history! I used this as my daily driver for over two years before I took it off the road as the 1.3 carb engine was getting tired, also a friend of mine had a 1H G60 lump from a Rallye sat there, so I snapped it up! Anyway enough history for now here's a picture of the car as it sits currently!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530405/8DDC161C-F1BA-4A8E-91C0-CF072EB465E7.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530405/CABD2FAB-E0D9-4640-81DD-761F0BD35918.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530405/81985D39-AB24-42F7-93B0-A68855EF3F77.jpg)
Excuse the 70s carpet that's left from the previous house owner!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530405/6CECB01C-EED0-4EEE-B645-300E01E67467.jpg)
That's it for now I'll try and get some more up tomorrow!
Last edit: by Panch_mk1golf
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/3image.png)
![re1900 in the usergroup ‘Paid Member’ re1900 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![re1900 in the usergroup ‘Local’ re1900 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Mk1 1983 Helios Blue GTI Engineering
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530835/oldcar.gif)
Here's one of the 1.3 before I removed it.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530835/DSCF4853.jpg)
Original seats, I don't actually have a photo of these in the car but they have since gone to the scrap yard!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530835/P1010289.jpg)
One of the current engine when I got it, it was a low mileage engine but I decided for my own piece of mind I'd strip it down and check it didn't have any nasty surprises hiding away.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530835/spacer014.jpg)
I quickly noticed the the cam and head were damaged
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530835/DSCF1871.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530835/DSCF1872.jpg)
At the same time as I was doing this I sent the charger to G-werks for a rebuild but this turned out to have a damaged scroll, possibly also the cause of the head damage.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530835/Brokencharger.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530835/brokencharger2.jpg)
So I had to source another charger and a cylinder head, with it being a 1H engine this meant the head bolts are different. A second hand Rallye head was hard to come by so I bought a PG head and had it drilled out to fit the 1H. Head bolts were also long obsolete by this point so I sent them to arrow precision and they matched them up to ARP Sierra cosworth head studs, being one of the only choices I had I decided to use them. A piper 268 cam also fell into the mix around this time and the head was ported and machined 3 angle valves+seats.
Old+new
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530835/spacer008-2.jpg)
Head after its rework
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530835/spacer061.jpg)
Managed to pick up a second hand charger that had just been rebuilt by jabba sport with a 68mm pulley and stage 4 porting
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530835/Picture.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530972/AFE2B53C-AE1C-41F6-A59C-E747F984BE7F.jpg)
Eventually it came round to time to remove the old engine and get cracking with the G60
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530972/spacer040.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530972/spacer042.jpg)
Which left me with this
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530972/spacer044.jpg)
Next on the list was moving/renewing the chassis leg engine mount. Luckily a friend of mine was willing to do the welding.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530972/Picture015-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530972/Picture021.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530972/Picture024.jpg)
Next I painted up the new mount and removed the old one
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530972/Picture038.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530972/spacer042-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530976/spacer048-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530976/spacer044-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530976/spacer046-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530976/spacer045.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1530976/spacer043.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531126/DSC00329.jpg)
Fitted a windage tray and had a baffled sump made
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531126/spacer005.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531126/spacer004.jpg)
Fitted a new water pump and trialed the ARP head studs
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531126/spacer007-2.jpg)
In the mean time a set of recaro's on custom bases made there way into the car and a red stripe Gti rear bench but with the standard brown door cards this was all a bit much!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531126/DSCF5053.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531127/IMG_0717.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531127/IMG_0706.jpg)
Really enjoyed this car and how the K-jet drove, but it met its end at 170000 miles exactly and I broke it for spares and kept what was useful for the G60.
![image.jpeg image.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1461028074/uploads/attachments/571584e911db4.jpg)
![image.jpeg image.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1461028077/uploads/attachments/571584ec0e441.jpg)
Anyway next time back to the G60
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531129/P1000504.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/simon.jpeg)
Chairman
![36thcrazyfist in the usergroup ‘Moderators’ 36thcrazyfist in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![36thcrazyfist in the usergroup ‘Paid Member’ 36thcrazyfist in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![36thcrazyfist in the usergroup ‘chairman’ 36thcrazyfist in the usergroup ‘chairman’](https://vwgolfmk1.org.uk/themes/default/images_custom/alETPUG.png)
![36thcrazyfist in the usergroup ‘Administrators’ 36thcrazyfist in the usergroup ‘Administrators’](https://vwgolfmk1.org.uk/themes/default/images_custom/3KoSCEK.png)
Have you decided on an interior or have you stuck with the harlequin look?
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
![Banner](https://vwgolfmk1.org.uk/uploads/banners/2sig4.jpg)
The harlequin interior has long gone and does all match now haha
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531246/Picture041.jpg)
Brand new pump, stainless mounting cradle from Crazyquiffs
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531246/P1000465.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531246/P1000470.jpg)
Braided fuel lines
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531246/Picture048.jpg)
I also found out at this time that my filler neck had seen better days, it actually fell off!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531246/Picture097.jpg)
So I ordered up a new one, it is now fitted but I've never been impressed with the fit so I may take it off again and adjust it as they say
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531246/Picture099.jpg)
As you can see on the new one there wasn't much left to hold it on!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1531246/Picture100.jpg)
![Hurtig in the usergroup ‘Local’ Hurtig in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![:wub:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/wub.png)
How did you do the wiring for the fuel pump? I assume, that you also mounted a fuel relay?
1982 - Mk1 Golf 2.0 AGG 8v - 158 HP / 202 NM
_________________________________________
I thought about following your example and build one with a Bosch 4 pin relay, but got stock on primer as you write
![:|](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/mellow.png)
Cheers it's actually a Kia brown!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1532318/DSC00332.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1532318/spacer004-3.jpg)
Also did the rear beam mounts and fitted a rear roll bar
![](https://vwgolfmk1.org.uk/uploads/pbextract/1532318/Picture039.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1532318/Picture042.jpg)
The beam actually gets a full refresh later in the thread!
And the steering rack
![](https://vwgolfmk1.org.uk/uploads/pbextract/1532318/Picture026-2.jpg)
Sorry for some of the photos being poor but they are all I have and they were taken a while back!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1532468/intercooler1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1532468/spacer005-3.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1532468/spacer004-4.jpg)
Built up a collection of powder coated parts ready to fit up, I wanted to polish the rocker cover but changed my mind.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1532468/Picture046.jpg)
Fitted new track rod ends and steering rack boots.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1532468/Picture028.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1532668/spacer070.jpg)
Mated it up to a Gti gearbox and put the box and bottom end in the engine bay!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1532668/spacer080.jpg)
The Gti box didn't stay in there long though……..
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/008_zpse29681e9.jpg)
![Melteddrummer in the usergroup ‘Moderators’ Melteddrummer in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Melteddrummer in the usergroup ‘Paid Member’ Melteddrummer in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Melteddrummer in the usergroup ‘Local hero’ Melteddrummer in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
