What did you do to your MK1 today?
Last edit: by Kenneth Cartwright
On the drive
Myvalver 89 GTi Grey mk2 16v
Sunday - Cleaned windows inside & out, as well as lights front & rear & anything else resembling glass ) Shook the mats…
also cleaned my rims with treatment.
Bird decided to offload on my bonnet & windscreen ahem!
Took it for a spin when darkness fell… Looked shiney. MFA saying 31.3mpg - not bad Got back home & put under wraps…
Last edit: by Deandubya
2: Put gasket sealant around the rocker cover to stop the oil leak.
3: Fitted original front indicator unit to replace the old crappy copy one.
4: Fitted relay 292 to the fuse box so i now know if i leave my lights on.
A good day all considered.
Last edit: by andyphill
Iron X and a toothbrush
Steam cleaned
Cutting Polish and small Dremel pad
000grade wire wool
autoglym SRP
Project 32/Sonax BSD to seal.
one down three to go…
ps if you are driving in front of me on the way to a show, keep out of the way as I am not using the brakes from now on!
Replaced blown fog light…on sportline.
On the drive
165/45 on 8j
Re:
Greavesy said
Fixed the horn! Yes!!!
Mine was broken to, but it some how fixed it self. Lol
On the drive
Re:
ThanksDeandubya said
it's on a thread which just slot on, look at the opposite side & it's the same way… perhaps angle was too strong a word.. 'same way' or 'the same as the other side' being the passenger side.. a pic of where the card clips are… Drivers side..hopsandmovingon said
Ahh I shall have to view a members car for the angles.36thCrazyFist said
And don't forget to get really OCD and line up the handle with the other sideDeandubya said
pretty simple dude… unscrew the rear window winder - pop off the plastic from the centre (quite tricky but pull the outers of the round bit handle sides [|o|] if you know what i mean) which will show a pozi screw, take this off & the bezel… pop the rear door card gently & take out top upwards, from the seatbelt cover & you see the shell with the rear speaker too… put your hand in & have a feel about!Ã,Ã, Ã,Ã, then do the reverse to put your door card back on. SimplesÃ,Ã, Ã,Ã, p.s. don't forget which angle your handle was facing before putting it back on. 15 minutes job done.hopsandmovingon said
Visited my cabby, and took a charged battery to start her up.
primed and started first time. phew.
lots of condensation muck at bottom of dipstick and zero oil.
added 1 litre and few pints of fresh fuel and ran for twenty mins until settled down ,
even the exhaust hole noise it ran quietly phew
BUT ,, drivers door still held shut by string due to me dropping striker pin back plate into pillar.
looking at various pictures its the door card to come off, boooo its soooo brittle..
but will have to wait until warmer before moving plastic , snappit dammit regretit.
thanks to all those images of bare shell refurbs it shows from inside where striker pin would be and yes phew it has hopefully settled into cavity.
I do remember getting in one as a kid and being warned to keep clear to prevent snapping/straining it and not to catch seat belt on it. Ahh memories.
Now where did I put that lottery ticket ?????
Â
Got it.
Dropped it
Got it .
Dropped it
Got it almost seated. Dropped it.
Got it placed plastic bag to catch it incase I ….drop it.
Got it seated in carrier screwed in pin.
Big thanks.
For a little job.
What's next?
Mk1 second project cabriolet
MK1 first project cabriolet
1990 - Cabriolet GTI 1.8 (DX)
On the drive
Kenneth Cartwright said
Sorted gear linkage or better than was. On sportline.now can select rev.1.3 without second guessing
Always handy to know which gear you are in
Is he in for a surprise.
When he gets to meet his much younger, much bigger brother the Mk6 estate.
That'll have him behaving himself this driving season for sure!
CraigSherriff said
Finally fitted the focal component speakers into original pods / door card up front ! Waiting on amp and sub to arrive to complete the speaker set up
Amp & sub arrived, fitted the amp … Need a couple of extra bits to complete the sub install. Definitely worth every penny so far
