Firing Order-Timing with Strobe??
(In Topic #203077)
![OTB-BassBuggy in the usergroup ‘Regular’ OTB-BassBuggy in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Can Anyone Help me out with the Markers on Pully wheel?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/219image.jpg)
![jusdubbin in the usergroup ‘Local’ jusdubbin in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![LeeO in the usergroup ‘Paid Member’ LeeO in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![LeeO in the usergroup ‘Local’ LeeO in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
This is all covered in the Haynes.
Lee
2001 Zafira 1.8
2001 Zafira 1.8
2001 Zafira 1.8
2001 Zafira 1.8
https://www.vwheritage.com/shop/N0203535/vacuum-hose-3mm-braided-sold-per-metre/
2001 Zafira 1.8
2001 Zafira 1.8
I find running super unleaded 97-100 RON makes the car tick over smoother, feels a little more responsive and uses less petrol than normal 95RON unleaded
I don't use a timing light to set up my timing, you can set it up by driving it and listening to the engine.
1st off check and double check all the timing marks on the cambelt then mark where the dissy is so if it all goes wrong you can set it back to how it was before you started.
Get the car ticking over smoothly by turning the dissy and you will have to adjust the tick over speed as well.
Next you need 7mm spanner and a 13mm spanner a quiet road ideally with a hill if possible, get in the car and listen out for any "pinking" under load eg. 20 mph in 3rd gear and slowly push the accelerator to the floor.
If no "pinking" heard get out and advance the timing a little (turn dissy clockwise) and drive the car again listening out for pinking. Keep doing this till you can hear the pinking then retard the timing a little so the pinking stops.
Job done. :-)
I will try anything to get it right, so it means a lot any input you lot are giving me, as something has to work, if I just keep trying
I also Use 97 shell super pluss, it seems a lot better, also it tells you as you open car door on a little German sticker, Super Pluss Only
Right I am going to get the engine warm and have a go at working it out!!
Thanks and wish me luck haha
take the hose of the dissie and tape up the end of the hose coming from the inlet manifold.
If you cant adjust your strobe you will need to use it on the flywheel not the crank pulley. The first photo here:
View topic: Setting up timing, - pics - The Mk1 Golf Owners Club
and you are aiming to line up the diamond mark (which is 6 degrees BTDC) with the pointer on the casing.
HTH
Lee
2001 Zafira 1.8
2001 Zafira 1.8
2001 Zafira 1.8
2001 Zafira 1.8
Grey in colour = mixture is OK
White = mixture to lean
Black = to rich
Try and find a friendly garage which can hook your car up to a CO2 meter for beer money as that's the best way to check your mixture.
The mixture screw is very deep in the hole in the meter head and you won't be able to see it looking down the hole.
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
Thanks Mark
I am thinking to many years ago to my folks old corsa, was a 3 pot engine and the airflow meter was tiny but the same kind of feeling now come to think of it, oh no, so its been this all along, wish I would have known, now I do though, now its a case of finding one, at the right price!!?? DOnt think they do the screw, think its a full meter job!
Easy thing to try isget the car warm and increase the idle speed using the screw to about 1100 rpm then give the throttle a little blip then lower the idle to 1000 rpm and see if that's any better.
The bolt/screw in the meter head is for the mixture.
Pictures..
Idle screw fitted in throttle body. You need a 7mm spanner/socket.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1525502/CIMG9273_zpskaeko4al.jpg)
Old flat O-ring fitted to my idle screw which used to work it self lose, used to take about a month.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1525502/CIMG9275_zps2b0puoxu.jpg)
New O-ring fitted.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1525502/CIMG9277_zpswjz5bsow.jpg)
So with there not being a screw in the fuel metering head unit, that would have a big impact on amount of air/fuel mixture? So its sucking fair to much air and not enough fuel, vice versa??
Thank you for the pictures LeeO, BIG HELP, also, can you be a diamond and when you get a minute, could you take a birds eye view pic of your fuel metering head screw? Thanks, your a top man!!
Any O ring can be used and if you take the old one or idle screw to a motor factors they may have one they can give to you?
I'll get the size for you if needed as I measured mine.
I don't think I can do a photo of the mixture screw as I haven't ever removed it - and have read that it is best not to as they can be tricky to get back in. I have never seen a photo of one on google - you might have to buy a second hand air box just to get the screw!
Lee
2001 Zafira 1.8
2001 Zafira 1.8
