What did you do to your MK1 today?
On the drive
Myvalver 89 GTi Grey mk2 16v
New black carpet has also arrived from Newton Commercial so looking forward to getting the car back together soon.
1990 - Cabriolet GTI 1.8 (DX)
Removed washer bottle and cleaned it replaced hose.
Replaced header tank return hose from v.bad condition.
Booked a fabric roof dye/wash reproofing . Then got headache from hitting garage door in the brrrrr cold.
Next job order better weather.ðŸCEž
What's next?
Mk1 second project cabriolet
MK1 first project cabriolet
Chairman
It's gonna be a slow process, but there's a thread in your cars and projects on here, just look for #DudleywantstheD
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
On the drive
Kenneth Cartwright said
Just took caster for quick 10mile blast around the villages… nice to blow cob webs out of engine bay
aye the same, give it a right kicking on the way to work
I've actually not driven the "daily" since I got the Golf on the road back in october!
Hopefully tomorrow I get to bleed it and try it out. Pre roof fit works
On the drive
After umpteen attempts finally got her started let her warm up before I reversed out the garage only for her to cut out and stubbornly refuse to re start ended up having to push her back in to the garage.
Later on this week as previously planned her engine is going in to get a full overhaul so this grumpy oap behaviour in future will not be tolerated as she will be finally be restored to her joyful youth.
sportline now, that's the car i was waiting for….
On the drive
Chairman
Changed leaking roof hydraulic ram
Hopefully tomorrow I get to bleed it and try it out. Pre roof fit worksÂ
I think I had this issue as well, were you still getting power to the roof but nothing happening?
Follow us on:
Follow us on:
Chairman
Removed side trim on my new toy… good clean under swage lines. and replace some dodgy clips.. quick rub down with soap to see, paint markings. Next job, Cd radio in, tape out, new immobilizer, replace blown speakers in door. what size are the fronts again the never ending question..what size speakers..?
Are they round in the front or oblong?
If it's later and they're round its 15cm in the front and 6x4" in the back - if it's oblong it's 6x4" in the front and 10cm in the back
Follow us on:
Follow us on:
round mate cheers, yes power was getting there just pumping oil through the top seal on ram.. so wheel well filled with oil..36thCrazyFist said
was a nightmare getting fitting loose in situ. also you need to peel the inner liner, to access the pin and locking clip, from top of ram,change that to a circlip also. tools, small hammer, small flat instrument driver,14mm combi spanner, 13/14mm ratchet spanner. and plumbers plier to compress frame to allow circlip removal and frame pin, from top of ram.
Take parcel shelf out that helps also. try to keep the spring washers in correct locations and give a bit of grease. will try source a replacement ram, from and get some bulk bought… since the orings are perished, 20yrs old etc
On the drive
You really do get what you pay for what junk!!!
👉2001 Citi Golf Sonic Edition 1.6i 100bhp👈
Resorting to using Petrol (super unleaded no less) after WD40, Sticky stuff remover, meths, white spirit and heavy washing up liquid failed the task.
Pedal rubbers replaced, wiper speed sorted and ordered parts for a complete service, cambelt, water pump, thermostat, plugs, leads, dizzy cap, rotar, oil, filters and drive belt.
I call it No rush after the missus said there is no rush to get it built after only owning for a couple of weeks. She is right but like any project I have done its always taken over my mind and the important things in life miss out (chill baby)… Must get a thread going on it as its quite involved and hopefully will help others along the way
Can't wait to get her back on the road! Will need a polish and a bit of interior work done when she is home but the end is near i hope!
And made a cup of tea.
What's next?
hopsandmovingon said
Read everyone else's what they did to their mk1 today.
I always read everyone's just to see if I get inspired. Today drive my daily…bmw 330d to brize Norton. . Come home cuppa tea..then out for drive in new ride…. picking next issues to sort… still more fun than being sat at a desk.
On the drive
