diesel conversions whats the simplest
you really need to find out the gearbox code
the rad from a SB engine is a big one so that should be fine to use
you can exhange the manifold and exhaust for a gti version if you wish
thanks again for all the help,Where is the code located on the gearbox?
Underside of the bell housing
Just seen ad for 1Z engine with AAZ mechanical pump. It mentioned on here that the 1Z had ECU etc? Can the 1Z be run with mechanical pump or has the kid made a mistake on the engine code?
