Dash Instrument Lighting Fault
(In Topic #202489)
![Woollen in the usergroup ‘Newbie’ Woollen in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
When I put the headlights or sidelights on my rev counter stops working as does the MFA. Also the instrument binnacle does not light up. I suspect an earthing problem but I am not sure where to look. I checked the wiring at the headlights all connections were good. Any pointers would be great. Cheers.
That is from the Battery to the Frame, and frame to the engine/tranny. If you have a 80's mk1 your earthing cables are over 30 years old, and used up.
On the back of the instrument cluster there are 1 or 2 connectors, you can remove the connectors, remove the plastic shrouds off the connectors on the cluster, carefully pry off the mylar circuit foil from the plastic tongue.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1521218/DCP_6970-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1521218/DCP_6960.jpg)
On the Pad side of the tongue place 1 piece of electrical tape and return the mylar over the tongue, replace the shroud, and you have just "plumped" your pins to make better contact.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1521218/DCP_6969-1.jpg)
Your Clusters have a earthing wire it is brown, and usually on pin 2 of the main connector. You will use a 3m Scotch Wire splice to splice a wire about 4 inches back from the connector, and tie it directly to the Frame with a self tapping sheet metal screw and a solderless ring connector.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1521218/ground002.jpg)
![](https://i3.photobucket.com/albums/y65/briano1234/speedo/ground003.jpg)
If your Earthing Cables are flaky, which they can and usually are, the Auto and Electrons being stupid, will find any path it can to complete the circuit.
I have seen the Starters use Clutch Cables, Speedo Cables, Accelerator Cables, Sensor grounds, and Electronic Control Units (yep Main computers) for a ground path to complete the circuit. Which when putting 20-40 Amps of current through those usually fries the cluster, or ECU as well as the sensors…. Making for costly repairs.
Conversly, fuses that are blown, I have seen electrons re-route to secondary paths to battery….via other things and fuses….
Oh, and why VW in their wisdom left "live" wires without shielding is beyond my scope, as in the 2 bare connectors on the Hazards switch… I strongly urge you to use heat shrink on those to prevent blown Turn signal fuses.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1521218/DSCI0144.jpg)
Riddle me this;
What do Divorces, Good Coffee, and Electronics all have in common?
They all start with good grounds.
