Temp gauge problem
(In Topic #202132)
![MCCUE23 in the usergroup ‘Regular’ MCCUE23 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Temp gauge problem
![mbusby993 in the usergroup ‘Regular’ mbusby993 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Having a similar problem in my Cabrio, light flashes constantly as soon as all the dash light shave switched off.
![Hoppy in the usergroup ‘Regular’ Hoppy in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I re-did the connection to the sensor with a new clip and cleaned the surface of the sensor for a better connection but will replace with a new sensor if this is likely to be the issue?
mccue yeah genuine sensors are expensive and also nla from vw, try classic-vw.co.uk he has them for cheap. dont think they are genuine but they are good quality
VW in Cardiff has one
If your water gauge is in-op, but your petrol gauge works see:
Repairing your Flaky Water Temp Gauge | Volkswagen Owners Club Forum
If both your Water temp and Petrol gauge are inop, then it is usually the 10V stabilizer on the back of the speedo.
3 legs, key on, the middle is ground the top 10v the bottom is 12v or battery.
