Ticking sound after stainless steel manifold fitting
(In Topic #202091)
Gasket?
My cars going for mot in the next week or so and after fitting a 4-2-1 stainless steel manifold there's now a ticking sound coming from the engine bay, any ideas what this could be? Possibly a leak?
Lee
👉2001 Citi Golf Sonic Edition 1.6i 100bhp👈
91Jreg Sportline (now gone) For now 88 Ereg Mk2 16v (monza blue ) (now its gone too)Numerous mk1 tintops I should never have sold 😰 Oh and a TDI Touran as a daily ….latest toy mk5 Gti (showing my age) had to go serious money pit ,now cruising a Caddy Van
golfman16 said
Yup sounds like it's just not nipped up enough little more might do it
Cool thanks,
Is there a sequence to tightening up the bolts or doesn't it matter? Also should the bolts be new or is it okay to re use the old ones?
Thanks again!
golfman16 said
Old should be ok but new ones are always nicer to work with , don't think there is a sequence tbh I'd work from the outside in tryn keepin it as even as possible , was the gaskets renewed at the change ? Might be another cause .
Yeah new gasket but it was slightly different in that the standard gaskets were 4 separate pieces and the new one was one piece. Hoping I don't have to replace that
Just my 2 cents worth….
Maurice
'84 GTI Cabriolet (undergoing rework and upgrades)
'83 T25 Caravelle (Daily Driver)
'95 T25 Caravelle/Camper (SA import, awaiting re-commissioning)
'96 Toyota Hilux Surf (Daily Driver)
'73 Beetle Based Trike (project)
GSF, Euro car parts should sell them as should a good motor factors or you can get them delivered to your door in a couple of days for £2.75.
http://www.ebay.co.uk/itm/VW-GOLF-MK1-MK2-MK3-T25-CAMPER-CORRADO-EXHAUST-MANIFOLD-LOCK-NUTS-x-8-A713-/191413095873?fits=Model%3AGolf&hash=item2c911c0dc1:g:Bv8AAOSwnDxUbael
mark1gls said
It's best to fit new nuts as they will be even harder to remove next time as being heated up and cooled down lots of time does things to metal, new nuts also have a locking collar so they don't work them selves lose.
Thanks for the advice guys!
I've bought new nuts so time will tell. I'm dredging having to do this as is a bit of a mission with only car ramps to work with!
Wish me luck!
MCCUE23 said
Is it not just easier to take the inlet manifold off to get better access rather then struggling from underneath
Good point, I'm pretty new to mechanics but is that the better way to go? Someone told me I could mess up something if I took the inlet mani off?
a bit of toilet tissue waved about round the joints will help you track down any leaks, if you see it flapping about there you go
If you have removed the inlet manifold recently then you may be fine removing it again but you will need a new gasket if you have not removed the inlet manifold I would leave it well alone as it can be difficult to remove it.
I worked from under the engine at the back as you can easily see the 4 bottom bolts and you can see 2 bolts at the top either end of the head it's just the top 2 middle bolts which are hard to see.
So I tried the tissue method and it didn't move this was after installing the new nuts. It's still making the ticking sound though! If it was the mani gasket would the ticking sound speed up with acceleration? I tried tightening the inlet mani bolts but they didn't budge. Any ideas what else it could be?
1983 mk1 golf gti
but yeah, check the timing is correct etc and look for soot stains round the manifold flange etc
