Help with abf twin 45s
(In Topic #196265)
Management
Currently sourcing parts for a engine conversion
I have bought an abf rebuilt ready to go (engine only) no ecu wiring ect ect
I'm going to run twin 45s what's the easiest way for management ?
And pros and cons for mega squirt emerald ect ect
My Auto electrician friend has toldme I dont need an ecu and I could run it with some ignition lives which I dont really understand ?
Thanks in advance
1 - Earth to battery -ve
2 - KR ign controller plug
3 - TCI-H plug
4 - Black - KR ign controller & TCI-H ign live - terminal 15 side of coil
5 - Green - Coil trigger - terminal 1 side of coil
\- red/black - spade is for the isv control unit, the main wire is the rev counter feed
6 - Brown - Earth to cylinder head
7 - Blue/white - Temp sensor feed (use one of the 3 on the side of the head)
8 - Dizzy plug
9 - red/yellow - Fuel pump relay earth trigger
\- black/yellow - idle switch feed (12v feed with throttle shut)
easiest would be kr or 9a dizzy plus a kr ecu and loom. you'll need a mk2 coil too, and if the car is on points and it has the purpl/white wire to the coil bin this and run your own.
i don't understand (if the car is on points)
If you don't know what they are I guess you don't have them.
They look like this.
http://www.ebay.co.uk/itm/VW-IGNITION-POINTS-CONTACT-SET-1970-Beetle-T2-Camper-Golf-Mk1-T25-Transporter-/171267746957?hash=item27e05a6c8d:g:mmwAAMXQk-FRERbz
Appreciate the help !
