Rear bulb holder contact
(In Topic #201201)
jellybelly said
pop a photo up that will help us understand whats up
If you can see it lifting in this pic, if I press down as in second pic the bulb works
jellybelly said
that looks altho the spring bit of metal in the rear of the 2nd pic isnt pushing the bulb up enough to make a good contact
thats why when you press down in makes contact
try tweeking it up a bit
Ahh I see what you mean, will give that a try and let you know it works thanks!
Worked perfectly! Chuffed with that as they don't make those holders anymorejellybelly said
also give the back of the bulb and also the springy bit it makes contact with a little rub with sand paper or wire wool just the clean the mateing surfaces for a better contact
