My 83 abf air ride project
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160123_161047.jpg)
![sallyandsean in the usergroup ‘Old timer’ sallyandsean in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Diverwez said
Looks really good pal, how does the car drive now you have it setup, I'm on budget coilovers at the moment and its shocking to drive, is it a comfy ride?
Not as good as I thought it would be. It has the firmness of coilovers but without the bangs if that makes sense.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20180706_160200.jpg)
![GolyTheGolf in the usergroup ‘Paid Member’ GolyTheGolf in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![GolyTheGolf in the usergroup ‘Old timer’ GolyTheGolf in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I have been researching air suspension a lot over the past 12 months and I was just wondering a bit about your set up.
I know these dampers are adjustable so I'm guessing you have them on the softest setting?
Also what sort of pressures have you tried because I'm sure that air shouldn't be as harsh as coilovers.
How did you go about setting it all up or is that still an on going process?
Sorry about all the questions but I'm a massive air fan and haven't got much info on the D2 kit yet.
Britney
Goly The Golf, a 1983 5dr 1.3cl having a full resto.
I've been told that it takes a while to get the set up right but once it's done you shouldn't have to touch it again.
One bit of information I read said to try starting with the bags at 10 psi (as long as there is enough ground clearance) and work up, in increments of 10psi, to 100psi and find what's best for the car and driver.
GolyTheGolf said
That sounds like a good pressure to be running at.
That sounds like a good idea!!!
![g60pjl in the usergroup ‘Paid Member’ g60pjl in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![g60pjl in the usergroup ‘Local’ g60pjl in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
g60pjl said
I'm new to this as well , by adjusting the ride pressure , will that alter the ride height as well ?
Ye the more air you put in the higher it goes.
1.8T CABBY
1.8T CABBY
richyhill said
Congratulations mate, great to see someone doing their own air installs, I know a few on here have, and I like to have a crack at stuff, but not sure I could. Looks ace, love it slammed
Cheers pal. It's not that it's a hard job you just have to take your time and plan it all out first.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/95image.jpg)
![Dubbuds in the usergroup ‘Old timer’ Dubbuds in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Mantap
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/thematic/food.png)
![mk1 daz in the usergroup ‘Old timer’ mk1 daz in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
How did that happen? Did it rub the body or tyre and is it the one side or both?
Gutted for you mate.
GolyTheGolf said
Oh no!!!![]()
Rubbed on the inside of the suspension turret. Just ordered another set of smaller bags so not the end of the world but had to throw another £200 at it.
Gutted for you…
mk1 daz said
Thing is you order the bags for the mk1 so they should of known which size bag to sell you!
Gutted for you…
I know, had that same argument just to be told bags not covered under warranty and I should have made the necessary mods to the car….
Last edit: by sallyandsean
Proper shame that mate and typical swerve tactic by manufacturers
Good luck with the re fit though ,and hope the smaller bags do the trick
1.8T CABBY
1.8T CABBY
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMAG0084.jpg)
![Diverwez in the usergroup ‘Local’ Diverwez in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
sallyandsean said
Gutted for you…
Bang out of order!!
I'd agree if the wheels had caused the damage as that's an ofset problem but rubbing on arch!
Do they supply a hammer to modify the inner archaic then?!?
