Help. injector 3 loose after checking spray pattern
(In Topic #196620)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG-20181013-WA0008.jpg)
![Bradcab in the usergroup ‘Paid Member’ Bradcab in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Bradcab in the usergroup ‘Local’ Bradcab in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Although the top green rubber seal seems to seal it ok the injector now wobbles a bit making me think that a seal or insert lower down is nakered.
Cheap part to replace and easy to remove the insert?
what age is the car?
Finally got there and swapped all the lower inserts, rubber seals top and bottom and then cleaned up the brass insert
Im glad i did it now jonny because the cars a bit more responsive. Must of had a little leak around the seals maybe. Still not perfect but every cloud and all that lol
Im pretty competant at all mechanical stuff like the head off and doing everything top to bottom but ignition timing is something ive always avoided in fear of bending valves :s
Is it easy to check the base idle as you called it and do the ignition timing Jonny??
all you need is a billy basic timing light, but id be sure to get an inductive pickup one. 1st step is unscrew the big plastic bung on top of the gearbox so you can see the flywheel. Turn the engine over on the crank socket till the cam marks line up and check the flywheel punch mark is also lined up. Note crank turns twice for every rotation of the cam so you may need to turn it over another 180. If you really cant get the bung out you could get a timing light with an advance wheel, dial in 6 deg BTDC and use the crank pulley timing mark
Once happy cam and crank are lined up pop the timing light on lead #1 get the engine good and hot then pull the vac pipe off the dizzy and plug it. Poi9nt the light at flywheel hole and check the diamond lines up, if not rotate the dizzy till it does. If the idle changes adjust the screw on the back of the throttle body.
once happy you can set the CO if you have decent equipment, I found the DIY kits to be pretty pants so may be worth takin it to local garage and asking em to tweak it in exchange for some back pocket tax free cash. If you want to fiddle you need a long allen key to reach down the hole next to the rubber boot behind the metering head.
you can usually add a couple degrees more advance, take it for a good hard thrash listening for pinking then pull the timing back a bit if you hear any. Tbh I just dal in 8 and forget, thats a pretty safe figure on proper 97-99 ron fuel as i cant really be bothered to mess about too much
this thread covers kjet in more detail, its for a 16v but the co procedure is the same. ignore the red/black wire plug I mention thats 16v only:
http://www.clubgti.com/showthread.php?195423
this one is for digifant GTI, but shows the 8v timing markers in more detail:
http://www.clubgti.com/showthread.php?124949
Someone at work will defo have a timing light i can borrow and then i will have a crack at it. When you say pull the pipe of the dizzy and plug it, is that plug the pipe or the actually dizzy connection?
Am i right in thinking aswell that im much better running it on the premium unleaded instead of standard 95??
Last edit: by Bradcab
you definitely need to run it on super if its a GTI, on 95 ron you'll probably find you got to back the timing off a bit to stop it pinking
