Sportline Horn Poorly
(In Topic #196423)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20150516_125016.jpg)
![GTi_Fan in the usergroup ‘Local’ GTi_Fan in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![ppc229w in the usergroup ‘Paid Member’ ppc229w in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![ppc229w in the usergroup ‘Old timer’ ppc229w in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Give it a clean up first and then run live and earth direct to test
lhasa green 83 gti tintop MOT passed Aug '14 after nearly 12 years!
Audi A6 3.0 tdi Avant Quattro Le Mans 305bhp
rubjonny said
chek the horn relay too, make sure it clicks when button is pressed
Is that on the fuseboard under the passenger side of the dash? I don't have an owner's manual so not sure if there are other bits located elsewhere.
![golfcabrio in the usergroup ‘Moderators’ golfcabrio in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![golfcabrio in the usergroup ‘Local hero’ golfcabrio in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
All joking aside, I don't know if they relocated for RHD but I presume not.
Take a torch and have a feel around, you can't miss it.
![001.JPG 001.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1508058319/uploads/attachments/59e324cda030d.jpg)
http://www.clubgti.com/showthread.php?219775
The relay by the way does click when the horn activates, so presumably rules that out.
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/eagle.png)
![Jetcolour in the usergroup ‘Regular’ Jetcolour in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
try another 53 relay just to be sure, its a common relay used mk1/2/3 so you wont struggle to find a spare if you have a decent scrappy local. the yellow/black wire to the horns should have a good ignition live, the earth is whats switched by the horn relay.
make sure these wires are all buffed up shiny, if that doesnt help it could be the horns themselves. take em off and spray a good blast of penetratying oil down the trumpets and give it a good swish about then drain. plug in and see if they go off, if they do then get some kind of silicone spray down there to lube and refit. might be an idea to spray a quick blast while someone is parping them, get it all inside the workings. ear defenders may be a plan
