My Mars Red 1.3 C 1983 Jetta
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2012-11-24%2015.jpg)
![Gordonthegolfer in the usergroup ‘Moderators’ Gordonthegolfer in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Gordonthegolfer in the usergroup ‘Regional Hosts’ Gordonthegolfer in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Gordonthegolfer in the usergroup ‘Old timer’ Gordonthegolfer in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Jettas looking splendid!
Chris
![Spilz in the usergroup ‘Local’ Spilz in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Just want to drive it now!
![](https://i72.photobucket.com/albums/i166/corsaspilz/sig2-2.jpg)
![Avatar](https://i95.photobucket.com/albums/l155/andysmith1980/MK1%20Golf%20GTI/rsz_golfmk11.jpg)
![smudger in the usergroup ‘Local hero’ smudger in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Grrrr, went to take my mate out for a spin in it today, got to his and he said "show us what youve been doing to it then" so i popped the bonnet, and immediately noticed fuel dripping out the back of the carb…
Also finally stuck a voltmeter on her, and alternator isn't charging the battery, gonna get her booked it for a bit of love, I still need to get the cambelt done so might aswell get a professional eye on it.
Will post results haha.
Since last time I posted in this thread, the fuel dripping from the Carb was because something on the Carb was caught on the bottom of the air box, I don't know what but it was causing fuel to seep out. All sorted though.
A trip to Ultimate Dubs led to some new cleaning stuff!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1282947/20130310_153710_resized_zps9ebe08e3.jpg)
Problems wise, it turned out the Alternator was kerplunked, due to the head gasket leaking oil onto it. Apparently common on the GF engine. So rather than just sort the alternator I went the whole hog and dropped the car at my mates for some "big jobs" (stuff I don't want to do).
Namely the Head gasket and the Cam belt. Full credit to my mate he spent a couple of hours a night for a week working on it in the freezing cold. I know how cold it was because I was watching and passing stuff haha. With the Jetta's nose sticking into his parent's garage the work was done!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1282947/20130322_191222_resized_zps03486cbb.jpg)
What was going to be the Head gasket and cam belt turned out to be a bit more though!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1282947/20130322_185849_zps5653533d.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1282947/20130322_192329_resized_zpsd2a69528.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1282947/20130323_152856_zpsf1d41c2a.jpg)
That rail under the rocker cover on the pic above, anyone know what it is? it had come off and was above the rockers, put it back and it seemed secure.
Anyway, bearing in mind I got a quote for £650 from a garage locally for a cam belt change and head gasket… My mate ended up doing the Head Gasket set, Alternator, Cam Belt, wire tidy, fitted a new rad, new thermostat, coolant flush, oil and filter change, and the Jetta was back together! All for £150!
She would only turn over intermittently though for some reason, I found the main power lead to the starter had seen better days,
![](https://vwgolfmk1.org.uk/uploads/pbextract/1282947/20130223_104711_zpsce3453a0.jpg)
so I replaced that sharpish!
Other than that the only issue is coolant leaking from where the flange meets the stat housing, I can't seem to find a gasket so it may have to be a sealant jobby!
Finally discovered today that the intermittent starting is down to a duff battery, put the battery on from my dads Golf and she fired up fine, proper lumpy, but I think I ran her a bit low on the old jungle juice.
Revs seem to stick a bit until I rev a few times… Not too worried though, just want to get to Big Bang!
When he'd finished he said "call it £120 mate"
What a guy… Gave him the £150 obviously lol.
Ordered my battery last night so when that's on she'l be ok I think, got a bit of water coming from near the Heater Matrix so got to investigate that at the weekend.
She runs ok, took her for a spin with my dad and she seemed fine, timing may be slightly out so my mates gonna check.
Fingers crossed she'l get to Big Bang for a good weekend, and hopefully a chat with some Mk1 owners!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/95image.jpg)
![Dubbuds in the usergroup ‘Old timer’ Dubbuds in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1289022/8651935221_e21c09cdfb_b_zpsf344b86c.jpg)
Also a quick shot off my phone of the engine bay as it stands, next plans are to hit this with the stick. Powder coating/zinc plating anything I can. I've got a manifold shield on the way with a pipe for the air box. Pretty chuffed with it so far under the bay considering what it was like!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1289022/20130409_171702_zps9064dc02.jpg)
Last edit: by Spilz
![CR51SAY in the usergroup ‘Regular’ CR51SAY in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![kernewek in the usergroup ‘Regular’ kernewek in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![:cool:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cool.png)
Did you ever find out what rims they are? (They're almost identical to the early T4 Multivan rims, but obviously with four bolts instead of five)
~ Craig
'77 Golf 1.5D
Still no idea what the wheels are, someone mentioned Passat GT but I don't think thats what they are.
![terencem215 in the usergroup ‘Regular’ terencem215 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
