Fitting an aux in Jack to your old radio for less than £2
(In Topic #195925)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/s2crop.jpg)
Marketing Manager
![Nosmonkey in the usergroup ‘Old timer’ Nosmonkey in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
You will need:
Normally Closed mechanically switched 3.5mm Jack (available from ebay for £1.79)
80-200 ohm resistor
Wiring (I used about 2m of 22awg wiring)
Multimeter
Soldering iron and solder
So this is the 3.5mm aux connector
![](https://i217.photobucket.com/albums/cc281/nosbanger/9C3FC40F-A31C-4588-856D-31E5F5B0073C_zpsc9qjgjg1.jpg)
5 pins out the back
![](https://i217.photobucket.com/albums/cc281/nosbanger/F243641E-0847-42CC-ACB9-9800CCD1B91B_zpsoco3aha6.jpg)
So these are the connectors and pin outs, wire colours will obviously be different to yours. I just used whatever I had at hand
![](https://i217.photobucket.com/albums/cc281/nosbanger/D2241FBE-62D7-4F23-94C4-C268ADA8234B_zpskzo6rda1.jpg)
All soldered up
![](https://i217.photobucket.com/albums/cc281/nosbanger/A0FFCDD1-F1CF-4873-8AE2-D9475DC7FC4B_zpswnh693ad.jpg)
To make wiring in the radio simpler, I soldered a 100 ohm to the end of the yellow source wire and then soldered that to the green wire running to the source wire on the potentiometer.
![](https://i217.photobucket.com/albums/cc281/nosbanger/D45F0130-02D9-4365-807A-B49387D8F80B_zpsevg7gjp0.jpg)
The potentiometer controls the on/off, volume and tone on this radio there are 3 pins, one is the source, the middle is for the volume control and the third is the ground.
![](https://i217.photobucket.com/albums/cc281/nosbanger/1D5384A9-985F-4522-85E1-B9376F241762_zpsntpfmzvu.jpg)
The three vertical pins on the top left are for the potentiometer. Using the multimeter I found the lowest pin to be the ground wire. The middle is always for the volume control so by elimination the top pin was the source.
![](https://i217.photobucket.com/albums/cc281/nosbanger/A1D3D310-B09A-4BD0-96C2-B10E5AE7D65F_zpsugsqfe8q.jpg)
What needs to be done is the wire running to the source needs to be disconnected (use a sharp knife or screwdriver to break the copper wire on the motherboard). PIN 3 (white/black wire) needs to be soldered on the tuner side of this broken connection, and pins 2 and 5 need to be soldered onto the potentiometer side of the broken connection. The earth should be soldered to the earth (durr)
![](https://i217.photobucket.com/albums/cc281/nosbanger/C2A5C11C-AFBF-4875-92DA-32E41D35811B_zpstvuojlge.jpg)
Test both aux and the radio. With the lead plugged in it should automatically play from the aux, when removed it will switch to the radio.
![](https://i217.photobucket.com/albums/cc281/nosbanger/16D1675D-0529-4274-B4C2-E527B7C9B69A_zpsm3xfqdkb.jpg)
Put the kettle on, have a brew and then refit your radio!
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwheresmysammich.com%2Fimages%2F51944.gif)
1973 BMW 3.0CS "Helga"
1981 VW Golf GTi "Agolf"
1986 Ford Escort RS Turbo S2
1987 BMW M535i - 'Klaus'
Instagram: @ahmet_e9
Marketing Manager
![merp0 in the usergroup ‘Local’ merp0 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/6J7A7209-30.jpg)
![scottyr1 in the usergroup ‘Paid Member’ scottyr1 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![scottyr1 in the usergroup ‘Old timer’ scottyr1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Tall bloke in the usergroup ‘Regular’ Tall bloke in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Tall bloke said
Sooner or later someone will start producing retro looking DAB car radios. Has anyone found one yet?
Over here, they make a wide variety of replacements including a "Chevy" "WonderBar"… but they are pricey.
Classic Car Radio - Classic Car Stereo | ClassicCarStereos.com
Vintage Radios for Classic Cars
Just two that come to mind.
