G60 Conversion
Is g5 OK as a cranking live for the relays?
I suspect there is no fuse as it was run on carbs before
as for the fuel issue it could be wiring or relay issue, or a bad ecu perhaps.
the above could be related to the fuel issue or not so we need to check a few things over such as checking the rail has power when the pump is on tfor starters, then we can work from here.
you would want to make sure the ecu is getting power too, could be we have 2 issues that are seperate ecu not powering so no injector firte plus issue with the fuel relay wiring making it come on all the time with ignition rather than only triggered by ecu
I will give it a listen tonight.
Thanks John
I'm a little confused about the shrill noise coming from around the throttle body. Is this normal, can another G60 owner comment?
Rich
The ecu and fuel pump relay and ecu pin1 feed were combined and connected to a constant live when in fact the ecu pin 1 should get cranking power only.
I have wired the ecu pin 1 to c/18 and relays to g5 constant live and now it primes properly
At the weekend I will do another video. Just finishing off the dials and tidying the wiring loom.
Set the car back to tdc as need to adjust the throttle cable as it's a bit slack and gave me the fright of my life when setting it up last as the pedal stuck down!
Got a genuine fuel relay wired in now .
Need to get some brake fluid in and adjust the gear cable as reverse has disappeared Are the butterfly flaps on the throttle body known to vibrate? I believe that is the origin of the shrill sound.
- YouTube
Last edit: by Rich.
I've been busy sorting out a few last minute tweaks, can't find that elusive noise though. Dad and I have searched high and low. Took the aux belt off to eliminate the charger, water pump, tensioners and alternator and the sound is still there. I have also re seated the inlet and exhaust manifold and no change.
The sound remains the same pitch and disappears at 2000 rpm+. I'm going to ask the garage to have a quick listen when I book the MOT.
Well DVLA have been kind to me and the car is now a 1.8 . Hopefully MOT next Wednesday!
Anyway some pics, was pretty sure this was the cause of my noise, can't believe I didn't notice when first fitted.
Can you see the problem lol
First gasket left I bought and new one made on right:
Throttle body:
Made up a custom stainless bracket to hold my washer bottle using the existing mount
Oh and a cheeky horn snuck in:
Oh and the car out for a clean:
So there we go, wish me luck for next week
Last edit: by Rich.
good luck for the MOT and enjoy driving it.
Good spot on the gasket, it's usually something simple - which makes finding it very hard!
mark1gls said
Splendid job you have done there and good to see it out of your garage..
Cheers Mark, MOT is now booked for Wednesday 18th in the afternoon! haven't felt this nervous in a while lol
Hairyarse said
I may have said this before, but I'm not usually a fan of yellow cars but that looks stunning, I love it! You should be proud of that one
Thanks Andy, it's a colour I wouldn't normally go for but when I saw it in person fell in love.
Andy#3
Melteddrummer said
She's looking gorgeous Rich, a credit to you!!
Andy#3
Cheers Andy, if only I could sort out that sound
