1.1 to a 1.8T
(In Topic #195059)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/fireman.png)
![Tiernan in the usergroup ‘Paid Member’ Tiernan in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Tiernan in the usergroup ‘Regular’ Tiernan in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
engine mounts
![dik-van-dub in the usergroup ‘Local’ dik-van-dub in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Old dubs never die, they just get lower
I'm guessing so could be wrong?
![mrpurple in the usergroup ‘Paid Member’ mrpurple in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![mrpurple in the usergroup ‘Local’ mrpurple in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
mrpurple said
Yes you need to move the mount, drill out the spot welds on the original small block mount and move it back and through 180 to the big block mount. There's plenty of pics out there to show you where it need to move to if you're unsure.
by any chance do u know how much the mount has to be moved back.
really appreciate the help
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/th_fff9e3ea.jpg)
![Brad. in the usergroup ‘Old timer’ Brad. in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fvwtech.no-ip.info%2Fimages%2Fgolf%2Fmk1bigmount1.jpg)
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fvwtech.no-ip.info%2Fimages%2Fgolf%2Fmk1bigmount2.jpg)
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fvwtech.no-ip.info%2Fimages%2Fgolf%2Fmk1bigmount3.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/4image.png)
![Webberna in the usergroup ‘Local’ Webberna in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Webberna said
Mark classic vw Carter does the mounts and he will give you all the advice you need. He is also a sponcer of the site so give a discount to paid members.
I have a set bought lad, but if they don't work out I'll give him a shout
can anyone help me with the drive shafts
what car can I get them off?
or do they have to be made to suit?
later 02j have 108mm flanges so you need early/low spec 02j or late 02a 100mm flanges to replace em
As I say other problem is sometimes the 02j box has 108mm flanges on it, so those need swapping for 100mm ones
mk2-4 shafts are the wrong length!
