3a query
(In Topic #194743)
Mk1 golf gti
Mk1 golf gti project View topic: 1982 original Irish GTi - The Mk1 Golf Owners Club
mTDI corrado
Mk1 skoda octavia vrs combi
mTDI corrado
Mk1 golf gti
mTDI corrado
mTDI corrado
the 3a engine is basically identical to a dx just bigger bores and pistons. as i say the only thing is the dizzy, you need this to match the injection system you plan to run.
kjet needs a vacuum advance dizzy, and im pretty sure all 3a use some kind of ecu so the dizzy is basic type with no advance in so you need to use your old dizzy. only thign im not sure about is the size of the hole in the block, so compare it to the old dizzy. if its bigger, order yourself a tsr dizzy adaptor ring. also compare the gear on the dizzy, if the 3a one is different swap it over
