Anyone put Mini Cooper Crown Spoke wheels on a MK1 Golf? Issues?
(In Topic #194484)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/eagle.png)
![telboyofpeckham in the usergroup ‘Regular’ telboyofpeckham in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
17 inch alloy wheels and tyres removed from a 2003 BMW MINI Cooper S Tyre size - 205 45 17 Pcd - 4 x 100 Offset - ET48 Wheel width - 7J
![164255.jpg 164255.jpg](webkit-fake-url://37EFF82F-6D5A-48FF-ACB0-1B09BEFDA207/164255.jpg)
rubjonny said
the centre bore is too small, but will bolt up once this is corrected
Thank you very much, rubjonny.
Could you help me with the bore size too?
http://www.alloywheels.com/Mini-Mini-R53-Hatch-Alloy-Wheels
You can get spigot rigs on eBay to reduce size from Mk1 to fit these, quite cheap.
it would work though if the wheels were aftermarket and already had spiggots you could replace, I'd be pretty sure standard mini wheels wouldn't have them.
an alternative way to do it is if you have room get some hubcentric mini fitment spacers, and have the inner hole machined out to suit. could work out cheaper if you wanted a shop to do it anyway.
you'll also need wheel bolts as the VW ones are ball seating and mini/bmw are tapered. Mini and BMW wheel bolts are perfect as correct thread and 17mm bolt head just like VW
Thanks for putting me right , I have just bought a Cooper S and was thinking of bolting on a spare set of Golf wheels to stand it on whilst I refurbed the two piece wheels that it came with, but got it in my head the centre bores were the other way round! At least I know I can bolt the Golf wheels to it.
Interestingly I have just seen in a Mini mag that some 17inch BBS RA (not sure if replicas) have just come out to fit the BMW mini.
SUV look.
Slamming is so 2014….
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/5golf.jpg)
![jayc in the usergroup ‘Local’ jayc in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
