fueling a conversion
(In Topic #194329)
![frank-pearson in the usergroup ‘Regular’ frank-pearson in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
my mk1 has a g60 engine in it, it was originally a 1.1c so I presume not a lot in the way of a fuel pump, its got an aftermarket electric pump that's not been wired up very well but that's not the issue. the problem is when you go round a right hand corner with pretty much anything but a full tank the fuel all sloshes to the left hand side and you can hear the pump slurping for fuel but not getting any, hence starving the engine, so you have to come off the accelerator
has been suggested that baffles in the tank would help which I can see why, would a gti tank have these in as standard and the 1.1 wouldn't? otherwise im guessing its a case of cutting the tank open, putting some in and welding it back up which seems like a huge ballache
any easy ways around this other than keep putting fuel in….
cheers!
What height is your fuel pick up in the tank? If it's sitting to high then you will get starvation on cornering, Have you got a swirl pot fitted any where?
i'll grab some photos….
Looks like a bit of a boge job but I'm not up on g60 conversion so don't know what other people have used for fueling.
I was thinking this, so do I look for a gti tank?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20150419_124546.jpg)
![adz25 in the usergroup ‘Paid Member’ adz25 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![adz25 in the usergroup ‘Local’ adz25 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Im using an external swirl pot under the bonnet for mine but have a facet redtop under tge car feeding it. Then an injection pump ( bosch 044) feeding the fuel rail from the swirl pot. Not on the road yet mind you but runs, but should give plenty of fuel.
Some one else may be able to add to this also, when i was doing my research, there was mention of utilising a fuel accumulator from another VW under the car. Should come up on a search ad in sure its been mentioned on here before!
I did try a search but im not overly sure whats feeding what
ive got a mk3 vr6 fuel pump here which im sure would give enough fuel, theyre mounted under the tank in the mk3's but im not sure if I could get that to work in a golf? im sure i read something about people putting them in mk1 caddy tanks
fuel cell is looking more appealing
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/7avatar.jpg)
![Rich. in the usergroup ‘Paid Member’ Rich. in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Rich. in the usergroup ‘Old timer’ Rich. in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
You need a carb tank that has 2 outlets at the top like the gti. The big one is for the fuel filler neck to tank and the small one goes to the gravity valve in the wheel arch.
You can either purchase the plastic cabriolet swirl pot from mark at vw classics or source second hand.
Get a late cabriolet lift pump where the outlets go forward towards the wiring connector. You can use a polo lift pump but the outlets face away towards the back of the car and make running the fuel lines tricky.
Mount a gti fuel pump or Bosch 044 in the gti cradle. I bought a stainless version from CQ. Mount the swirl pot where the gti accumulator is positioned, again bought a stainless cradle from CQ.
Connect the fuel system like so:
![](https://vwgolfmk1.org.uk/uploads/pbextract/1468335/FuelPotSetupPolo.jpg)
Fuel filter can be mounted in the scuttle like I've done in my build.
Alternatively source a good gti tank (hard to come by) and gti fuel setup.
Rich
As you have the larger spare wheel you have the smaller 44l tank which is very hard to find a genuine gti tank, later 50l larger tanks can be bought new but don't fit as they are a different shape to wrap around the smaller space saver wheel well.
mark1gls said
I was going to say look at RichG thread as he's fitted a G60, even better you are going to see him, he's a very helpful chap with a stunning car. I had the pleasure of meeting him in the summer when I picked up an engine (still not got around to fitting it yet).
Ah that reminds me to reply to rich!
Thanks for the kind words Mark, you need to crack on with that engine for the summer
theres a wide range of aftermarket swirl pots which are fine, just make sure they have 4 outlets so it can be plumbed in as per factory.
rubjonny said
yup i would do it exactly as rich describes, unless a genuine gti tank falls in your lap. tap the lifter pump power to the main pump power and job is a jobbed job.
Hahaha you know of my wiring 'skills' please suggest options that are actually available to a monkey of my capability
I think I can handle this though
If I get the gti tank and pump what would I need to do from there and how does it differ to the feeble tank I have at the minute?
Thank you!
Clueless mk1 owner
looks like this:
View topic: Fuel Tank cleaning *HowTo* clear that blockage - The Mk1 Golf Owners Club
some pics of swirl pot assy after removal, showing the rubber bung that fails in here too:
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Ffuel-systems-and_3%2Ffuel-tank-condition
Not sure if I mentioned but my fuel guage just doesn't work, maybe it's not the case but I just saw a post about a mk2 with a dead fuel guage and it was said that the blue film needs to be pinned down for it to work, I had the clicks out replacing bulbs the other day and half of the blue film by the rev counter was hanging off. New clocks?
if you jump the purple/black to brown the gauge should go to full so start, if not leave this jumper in place while you fiddle with things. check the brown wire is earthed, it'll also power your lifter pump so you want this to be good otherwise your main pump will die!
