Mazza's Golf Driver Daily
Thing is just have a quick look out of the window at it …………. See you can't be mad at it long lol.
Have a great Christmas
Im hopefully picking up a new head next weekend and swapping over my cam etc. into that to hopefully solve the coolant burning issue. I will also take this head to be inspected properly at an engine shop. Once fitted with yet another headgasket kit with more new headbolts I will pray to the engine gods that my problem is solved. Should It turn out that the block is warped and the problem persists then I will be forced to sell my golf and buy a something less infuriating like a GeeWiz….
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
If its not boiling up or loosing water I'd find something else to worry about.
I had hoped that my engine was supposed to have dowel pins to locate the head and mine had just gone missing but I cant see and listed on vagcom so I dont this its even that!
If anyone wants a free mk1 pm me before I set mine on fire…
Keep going mate, times like this when you have gotta dig deep
Gouges in all the tappet bores
Damaged rocker cover mating surface
I wouldn't have thought the damage on the rocker cover flange is an issue. New gasket and gasket sealer should take care of it I would have thought
It was more the scraping to the insides of the hydrolic lifters which i thought might have scrapped it I managed to go back to the engine shop and they said I should take it off and let them pressure test it etc. or put an additive in because the coolant loss isnt actually that much so its probably only a slight crack or something. Although Im against putting additives in for this sort of thing as it seems a bit of a bodge!
Is that from das ebay?
Matt
Yeah it is, Ive only ever seen them come up for sale on ebay.de and this was the cheapest ive ever seen one so I snapped it up
They need a good clean-up, a new trumpet (one was damaged and a new but small one was supplied as a spare), a new gasket set, a throttle linkage, trumpet securing parts, a dust cover and probably loads of other parts which are all staring to look worryingly expensive
Still need to get to the bottom of the headgasket issue before i even start thinking about fitting these!
Matt
Looking forward to getting them fitted
That looks a pretty comprehensive service kit, I was looking at one that was £40 for both carbs but not sure it included as much as that so might end up paying £60 now
Its the cost of the little things like studs, cover plates and trumpets that are missing which is going to make them yet more expensive
Paul
- 1978 MK1 GL 2 door with 2.0 16v ABF, twin 40's, Recaros, lots of suspension mods. I'll get it back on the road one day.
- 1991 MK2 GTI 4 door. Was my daily doing over 1000 ks a week until it hit a truck. RIP. Got another one now and loving it!
- 1991 MK2 GTI 4 door for parts.
- 1998 Seat Cupra + another used as a donor for the MK1
- 1999 Passat Wagon. Needs street cred but at least it's a manual.
