Fly wheel mark problems
(In Topic #193265)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/trees.png)
![ZoFox in the usergroup ‘Regular’ ZoFox in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Basically i've had a rough Idle and suspected the timing belt i fitted was a couple of teeth out.
I only have the dimond on the fly wheel no little dot for TDC, can anyone help?
I can put a screwdriver in pot No1 for TDC but its hard to get it 100% on the rock.
Has anyone got the same fly wheel and found a way around this?
there is also a mark on the crank pulley that lines up to an arrow on the lower timing belt cover though
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/5golf.jpg)
![jayc in the usergroup ‘Local’ jayc in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I timed mine by ear. Emissions were spot on at MOT so can't e that far out.
