fusebox relay HELP :(
Hi
I want to know what relay go into the slots ive added a picture of my fusebox.
Thanks C:\fakepath\20150105_141224.jpg
n is hazard and turn signels
m is wipers
k is a kind of "charge up" for the system
m is wipers
Hi
Thanks for the Reply, which one is fuel pump relay?
L is the fuel relay, you need one with a fuse pushed into the top of it.
some had a factory recal where the fuel relay was fitted above the fusebox, as the fuel pump pin was prone to burnign out thanks to the pin beign under-sepc to take the load.
the empty socket above the fusebox is probably the rear wiper, but check wire colours
Hi mate
Thanks for your reply, theres a block on fuseboard at the top if you look at the picture its got a fuse inside it i believe thats the fuel pump relay i think lol.
C:\fakepath\2015-01-07 16.54.27.jpg
144 views (4 Mb)
the fuseblock on the right there is for the rear fogs, if it had front fogs the other one would be used too :)
for the old cermaic type fusebox the fuel pump fuse is fitted in the end of the relay:
