New mk1
My new addition
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/5702ccac3bbda.jpg)
![andyphill in the usergroup ‘Old timer’ andyphill in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Oldschoolcool in the usergroup ‘Paid Member’ Oldschoolcool in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Oldschoolcool in the usergroup ‘Local’ Oldschoolcool in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://i292.photobucket.com/albums/mm3/markee156/vinplate001.jpg)
![](https://i292.photobucket.com/albums/mm3/markee156/vinplate003.jpg)
![ivortheengine in the usergroup ‘Old timer’ ivortheengine in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Regards Volkswarren
![9double9 in the usergroup ‘Paid Member’ 9double9 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![9double9 in the usergroup ‘Local’ 9double9 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Sticker Pig
ivortheengine said
That's one of Hugh's rep plates looks well,what's left to do mark?
Still have to do brakes but will probably leave this to next year as I want to go to a few shows with the original wheels fitted. VDO gauges need connected, get horn working and I am sure I will find another few things along the way.
volkswarren said
the 1st choice was the correct place though.
Mmm, may need to move it then to keep it original. When I was looking at other photos there seem to be variations in where people put them, did VW change it from year to year or is this just personal preference?
No just people put them back in the wrong place, there are two sets of holes with the same spacing, but if you look it can't possibly go where you have it as the plate overhangs and may get damaged or bent.Oldschoolcool said
Regards Volkswarren
Thanks for info, will have to do it again! I wonder why the other 2 larger holes are there, is this for different markets?
![](https://i292.photobucket.com/albums/mm3/markee156/P1010054.jpg)
My new tools to ensure safe removal and a lack of rust inside the tailgate.
![](https://i292.photobucket.com/albums/mm3/markee156/P1010059.jpg)
![](https://i292.photobucket.com/albums/mm3/markee156/P1010063.jpg)
Had a tailgate trim for a mk2 golf (hard plastic) and measured it to find that the raised centre bit was almost the same size as the mk1 trim so set to work cutting it out.
![](https://i292.photobucket.com/albums/mm3/markee156/P1010057.jpg)
After a bit of filing the edges and drilling the trim clip holes it looked like this.
![](https://i292.photobucket.com/albums/mm3/markee156/P1010060.jpg)
All that was left to do was to see if it would fit!
![](https://i292.photobucket.com/albums/mm3/markee156/P1010061.jpg)
And it did; a slight bow in the middle as per the original item but it looks relatively uniform and will be more hardwearing than the original.
![](https://i292.photobucket.com/albums/mm3/markee156/P1010062.jpg)
I know it won't appeal to purists but it is a practical solution to a heavy traffic area of the car; and it is still using VW parts; can always put it back to original spec. easily.
![slippy in the usergroup ‘Old timer’ slippy in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![ppc229w in the usergroup ‘Paid Member’ ppc229w in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![ppc229w in the usergroup ‘Old timer’ ppc229w in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
lhasa green 83 gti tintop MOT passed Aug '14 after nearly 12 years!
Audi A6 3.0 tdi Avant Quattro Le Mans 305bhp
ivortheengine said
Good job mark and the dynax s50 is good stuff.
Yes Ivor, unfortunately they sent me the dark stuff as you had said the clear one was less messy, oh well, did not know till I started spraying!
ivortheengine said
Ring them they may help u out.the uc is very good.
Ok, may try that.
