Ignition timing on 1.8 carb keeps slipping out
![shandyandy77 in the usergroup ‘Local’ shandyandy77 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
look at pins D/7, G/5, G/2 and A/26 on the fusebox (see fusebox sticky)
I decided to check the coil, and found out that the one I got from euro car parts was the wrong one…it was for a car without electronic ignition. So I got a new one and put that on, and seems better. Also found the power to the choke heater had snapped! Weather is so warm at the moment that can't really tell if problem sorted, as need to test from cold start.
Thanks for your help, fingers crossed it is fixed
Also, did a compression test today and all 4 cylinders were spot on 14 bar….but Haynes says range is 10 to 13. Is this a issue.
