1.8 gti cylinder head bolt torque settings?
(In Topic #191988)
![whatisit in the usergroup ‘Local’ whatisit in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Haynes manual says:
10mm bolts
stage 1 - 65Nm
stage 2 - 1/4 turn
12mm bolts
Stage 1 - 40Nm
stage 2 - 60Nm
stage 3 - 75Nm
stage 4 - 1/4 turn.
Measured the bolts and they appear to be 10mm andso it looks like only 2 stages.
Just double checking that I am doing this right?????????
I know to tighten them in the correct order!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar%20small.jpg)
![Torker in the usergroup ‘Local’ Torker in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1983 Golf GT 2.1 16V with throttles/1978 Golf LS 2.1 ABF with throttles/2008 Citi Storm 1.4i/2007 Hyundai Getz - my daily
Pretty sure the bolts are 10mm, definitely smaller diameter than on my 2000 caddy sdi.
Should I be worried? can I still apply more torque to the bolts if needed?? 12mm got up to 75Nm + 1/4 turn
if they are the correct 1.8 mk1/2 type bolts then its fine to crack loose and/or re-torque as they can be re-used. I would follow the procedure again redoing 1 at a time rather than undoing them all and starting again if that makes sense
I thought these were stretch bolts also, not for re-use. Although if I torgued them more, would it just stretch them more? Someone mentioned they may snap?
I am no expert and respect your opinion as you have given good council to me in the past
http://www.vwspares.co.uk/g1gaskets.php
only the 16v and diesel bolts need to be replaced, the 8v ones can be reused. not that I would reuse original bolts, but since yours are new it should be ok. plus they havent been done up as tight as they should be even if they were stretch
looking again actually, the 12mm one doesnt look right either? the figures in my haynes, bentley and my VW manuals state 40nm, then 60nm, then either 1 stage of 180 degree or 2 stages of 90
This sounds familiar, I'm pretty sure this is how I torqued the head on my 2.0 8V as well…rubjonny said
theres only 1 type of bolt for 1.5-1.8 and that needs the 12mm setting, the 10mm procedure may be for 1.0-1.3 bolts? the diesel bolts are different again. either that or its for an older style of head bolt which has been superceeded, this is why i wanted to double check what bolts you bought:
only the 16v and diesel bolts need to be replaced, the 8v ones can be reused. not that I would reuse original bolts, but since yours are new it should be ok. plus they havent been done up as tight as they should be even if they were stretchlooking again actually, the 12mm one doesnt look right either? the figures in my haynes, bentley and my VW manuals state 40nm, then 60nm, then either 1 stage of 180 degree or 2 stages of 90
![hubbadubba in the usergroup ‘Local’ hubbadubba in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Those were the figures I was given by a local friendly garage when I did our 8v GTI on a mk2, he gets all his torque figures online, used new bolts as it was probably the first time the head had been off at 166k, 40, 60 then 2 x quarter turn was advice given
83 Candy White Campaign http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmk1-golf-restoration_2 89 Caddy pick up http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-other-cars-and_2%2Fcaddy-barn-find Mk1 Scirocco project completed
![LEZ1981 in the usergroup ‘Local’ LEZ1981 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![mattgti in the usergroup ‘Local’ mattgti in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Avatar](https://fbcdn-profile-a.akamaihd.net/hprofile-ak-xpt1/v/t1.0-1/p50x50/11707542_10153470072544104_2731197485213754674_n.jpg?oh=a36a566fcaf366ec265cca629673893e&oe=56415236&__gda__=1447281739_49a642a90f8c8b905b53d3f25669a529)
![Alex Cook in the usergroup ‘Newbie’ Alex Cook in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
I am mating a DX head to an ADY block and I was following the torque specs from my old skool Brown Haynes manual for the mk1…had gone through stage 2 (60nm) and was working through stage 3 75nm. Got to bolt #4 and SNAP - Brand new and snapped in half!
I was bemused as I'm most definitely not that strong….but a a good googling does suggest that we should really only be cranking it through to 60nm plus a nip…
It's a good job that I had a spare set of bolts kicking about!
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cool_flare.png)
![jakeblues68 in the usergroup ‘Newbie’ jakeblues68 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
![IMG_3614.JPG IMG_3614.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1524689477/uploads/attachments/5ae0ea42d0b72.jpg)
![IMG_3615.JPG IMG_3615.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1524689480/uploads/attachments/5ae0ea47a50d6.jpg)
