1993 Clipper - Starter motor (I suspect)
(In Topic #191636)
Just clicking until I hit the starter with a hammer
This has been ongoing on for a few years now, but getting worse now so I want to replace the starter to get it more reliable.
I have been looking now for a starter, but struggle to find the correct one. Is there a particular good place to find these - and how can I verify that it is the correct part?
Help appreciated.
VW Golf Clipper '93, BMW X5M, Abarth 595, VW ID3, Porsche 911-50th
Is that not the case for the clipper then ?
If it is two bolts only I might have indeed a look.
Where in the UK are you? If you're anywhere near me (Stamford PE9) you're welcome to come and try a spare I have to see if it solves the problem.
Would this be the right unit?
Starter from ebay
Once the panic was over, it fired up fine and now I have a starting car each time
It went through very smoothly anyway. I had lived with the "will it start or not" for quite a few years so it is great to be know it will start.
To me it sounds like your problem is a bad battery though if the power consumption from the starter takes all the power away from all other consumers.
It is normal that during the starting process major components such as lights, fan etc are switched off. But never the clock though.
Gony59 said
Before you fixed it… Wje. You turned the key and preyed Did the clock go out and all power seem to disappear (if so I may be replacing a starter motor!!)
Not necessarily bad battery, if the starter motor is jammed and the power's going to it it will pull a huge current, which will drop the available voltage from the battery quite a bit. Worth checking the battery is okay - the easiest way being to check its voltage once its rested for some time and under no load.
On a previous bad battery that was my symptom, the clock would reset on start attempts.
Easy check though via a jump lead to see if the starter will turn, if not - jammed starter. If it does, than bad battery.
