Intermittent electrical starting issue
(In Topic #190936)
![Aaron1 in the usergroup ‘Local’ Aaron1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Over recent months I have had an intermittent electrical starting issue that used to happen very rarely however now its more frequent.
When it happens I turn the key and have nothing whatsoever, sometimes if I back it off and try again it will turn over and sometimes not. On the occasions that it doesn't start it then may do when trying again later.
The starter motor was new a couple of years ago and I've cleaned up the chassis earth.
Listening to further suggestions.
Cheers.
Yet to check the ignition switch itself.
It wouldn't start last night but was okay after a bump start down a hill and was okay for the two times later in the evening.
The relay is clicking even when it doesn't turn over so I think that's fine, wiggling the key made no difference.
The keys are not heavy at all, only the ignition and petrol cap on the bunch.
Thoughts?
Cheers.
Just to let you know that I've been using a newly cut key the last few occasions and so far have been without trouble.
Weird I know, could be coincidence?
