Lights on buzzer mod for Mk1's :)
(In Topic #117458)
![m6m62 in the usergroup ‘Old timer’ m6m62 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
First up, I can?t take credit for the ?plug in? mod for the ?89 and later fuseboxes. Apparently this turned up on a French forum and then someone posted it on the Caddy Forum. However, due to the interest in this I spent a bit of time looking into how to get this to work on the pre ?89 S2 fuseboxes (ie, for the majority of Mk1?s). It was straight forward ! I haven?t got the means to try this on a S1 fusebox unfortunately.
Secondly, I?m not an auto electrician by any means. This is what I did to get the buzzer working on my ?83 Gti. Feel free to do the same but I can?t / won?t be responsible for any problems you may encounter should they arise
A - Find a donor !
The relay is a Seat part so you?ll need to locate one of the following Seat produced cars in the breakers :
Seat Ibiza 6K (?93-?02) or it?s Cordoba / Vario variants
Seat Inca van (?95-?03)
Caddy 9K van (?96-?05)
Polo Saloon / Estate (not hatch) ? similar years to the Caddy van
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fpic20.picturetrail.com%2FVOL1215%2F5574352%2F22656012%2F376750303.jpg)
B ? Get the parts
The fusebox can be found above the drivers side footwell on the donor car. You?ll need to take off the drivers side glovebox and remove the cardboard undertray to get at it properly. When you do you?ll see something like this. The relay we want is top left
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fpic20.picturetrail.com%2FVOL1215%2F5574352%2F22656012%2F376751089.jpg)
Carefully remove the relay from it?s plug. If you just pull on it then it?s likely that the relays cover will just come off. Wiggle it and maybe try and get a screwdriver behind to lever it off
Lift the fusebox from it?s mounts by pushing up the clips on the sides, then drop the box down
You can then take off the relay holder from the top of the fusebox. You need to push a screwdriver under it and lever it up while pulling it towards you
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fpic20.picturetrail.com%2FVOL1215%2F5574352%2F22656012%2F376750307.jpg)
When the holder is free spend some time tracing the wires back to the main loom and cut them there. You want as much wire on the plug as you can get as it?ll make things a bit easier later
When done you should have this :
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fpic20.picturetrail.com%2FVOL1215%2F5574352%2F22656012%2F376750310.jpg)
C ? Wire into your Mk1
You?ll need to isolate the battery before doing any work. When you?ve done that, remove the passenger side undertray and drop the fusebox down. Happily the Seat relay holder will slide right onto the top of a Mk1 fusebox. Pick your preferred location !
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fpic20.picturetrail.com%2FVOL1215%2F5574352%2F22656012%2F376750313.jpg)
Three of the 4 wires you?re looking for on the Mk1 loom terminate at the red plug on the rear of the fusebox. These are grey/red, grey/black and black/yellow :
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fpic20.picturetrail.com%2FVOL1215%2F5574352%2F22656012%2F376750318.jpg)
You need to connect as follows :
white/red on relay holder to grey/red on the Mk1 loom
white/black on relay holder to grey/black on the Mk1 loom
black/yellow on relay holder to black/yellow on Mk1 loom
How you connect the wires is personal preference although Scotch Lock are fine for this IMO.
The only other wire to connect is the brown/red on the relay holder. This connects to the brown/white door pin earth switch on the Mk1. I extended the wire from the relay holder, passed it through the body of the car and connected directly to the door pin switch (?piggyback? spade connector), but upto you where you trace the wire and attach.
Fit relay to holder
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fpic20.picturetrail.com%2FVOL1215%2F5574352%2F22656012%2F376750314.jpg)
Just have to refit everything, reconnect battery and test ! The buzzer will sound when the door opens if the lights are on but the ignition is off. It shouldn?t sound under any other condition.
Cheers !
Mark
m6m62
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Madferret in the usergroup ‘Old timer’ Madferret in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I presume you can just short the wire from the door switch to GND?
~Madferret
Mk1 1457cc 5door GX '83
Actually it would be good if a couple of people had a go and reported back as I only did this yesterday so haven't 'lived with it' as such
Cheers,
Mark
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/horse.png)
![Mobys in the usergroup ‘Regular’ Mobys in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![unityjon in the usergroup ‘Local’ unityjon in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
part number is 1hm 919 433a (it plays a little tune rather than just beeps or buzzes
58l - left sidelight
58r - right sidelight
85 - door pin earth
86 - ignition switch pin SU, or ignition live
![O_o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blink.gif)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/64image.jpg)
Life Member
![Dano in the usergroup ‘Moderators’ Dano in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Dano in the usergroup ‘Paid Member’ Dano in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Dano in the usergroup ‘Regional Hosts’ Dano in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Dano in the usergroup ‘Old timer’ Dano in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
unityjon said
it started as a random post on facebook and someone kindly searched the forumgood threads don't die they just get resurrected !
That was me!
![:$](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blush.png)
FB is great, but the forum is better for historical information and those hard to find answers.
Now, whatever happened to m6m62???
it took its toll on him…. ?
Life Member
Dunno after that. Think
![](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_20160516_173454.jpg)
