garage, timber or brick
(In Topic #189403)
advice, help choosing...
done right timber garages can look quite nice an appealing, the house is white brick which seems to be hard to find a match for from what ive looked at.
any suggestions or advice?
cheers, Brad
the house is in a quite cul-de-sac in a decent area (there are ok areas in sheffield )
here to help Brad, you have helped loads of people on here, glad I could be of some assistance
1979 mk1 Golf Gti (Dan)
2010 T5 Karmann Colorado
2012 mk6 Golf Tdi convertible
2019 Skoda Octavia Sport ( it’s Golf)
ant5 said
It is easy to insulate and fire proof timber. Timber might be more flexible and a non permanent structure so not tied to planning. And it's quicker.
cheers man, feel bad texting you all the time lol
im swaying towards timber at the moment, clad with shiplap for the looks, and as said its less likely for planning.
if a decent prefab comes along, usually go for 300-600 locally id be tempted.
correct me if im worng… once im in the house i will be ringing the council just to clarify
You can buy pre fabricated timber garages that just bolt together these look good and do not require skilled labour to erect.
lhasa green 83 gti tintop MOT passed Aug '14 after nearly 12 years!
Audi A6 3.0 tdi Avant Quattro Le Mans 305bhp
as ant said, insulate it properly and all is well, going to ask a brikie at work a rough price for a block built to weigh up…
They are also thin walled so moisture in the air will cool on the walls quicker in the winter.
If you do the same treatment to a wooden building (block up the vents) it will also suffer from damp, along with mold growth because of the timber treatment.
I'll stick to prefab (mainly because I have one lol)
the size i can build is pretty confusing im only a welder
planning:
"Maximum height of 2.5 metres in the case of a building, enclosure or container within two metres of a boundary of the curtilage of the dwellinghouse"
building regs:
"Building a detached garage of less than 30 square metres floor area would not normally need building regulations approval if:
the floor area of the detached garage is less than 15 square metres.
the floor area of the garage is between 15 square metres and 30 square metres, provided the garage is at least one metre from any boundary, or it is constructed from substantially non-combustible materials."
does this mean i can build close to my boundary if its brick or non cumbustible and doesnt exceed 30m2 or 2.5m in height (i want a flat roof)
going to ring the council later to ask them about it but want to know my facts first.
I plan on timber as I can do it myself and can easily change/adapt as required. I'll be cladding the outside of the brick garage in timber so from the side it look's like one 50ft long building.
golfcabrio said
Remember the story of the 'Big bad Wolf and the Three little Piglets'!
was just thinking that as reading the first post.
If it were me Brad I would go for brick for durability and security mate. Down to costs I suppose at the end of the day.
