Engine Clean
(In Topic #189124)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/192image.jpg)
![LennyD in the usergroup ‘Local’ LennyD in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://i1310.photobucket.com/albums/s658/LennyD1976/imagejpg4_zps6532c50f.jpg)
![](https://i1310.photobucket.com/albums/s658/LennyD1976/imagejpg1_zpsc415550e.jpg)
We'll today was the start of my engine clean. Must say it's come up better than I expected!!! The one thing I could do with a hand with would be some advice on new parts!!!
Do I remove all the genuine parts have them powder coated or try to buy replacements …. Things like the Brake servo, cam cover , rad fan cover , Rocker cover….. And so on… Got great feedback at the anniversary gathering on my car bodywork and interior so want to now get the engine upto scratch
I am mechanic so how difficult are theses parts to change … Would I be better getting someone to help ?
Any help would be great
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/9image.jpg)
![Massbad69 in the usergroup ‘Local hero’ Massbad69 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/130image.jpg)
![RichardHall in the usergroup ‘Local hero’ RichardHall in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![RichardHall in the usergroup ‘Moderators’ RichardHall in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
The Alternator should polish up like massband69s I did mine with a Dremel and a felt wheel and mortal polish.
You can get some copies if original stickers for coil, alternator and fuel meter head if you damage any - not sure what the cabbys had if the were the same as the original tintops.
![image.jpeg image.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1499975614/uploads/attachments/5967cfbe7c24a.jpg)
Then as Richard says, new stickers, shiny bolts and jubilees etc make all the difference.
Here's a link to where u get stainless bolts etc
http://www.liquidmetalrefinement.co.uk/store/c2/Mk1_Golf.html
Clean your washer bottle out with sand and gunk.
New washer hose for pennies.
New expansion tank hose as well.
Good rubber cleaner, I use Autoglym rubber cleaner.
I am also looking for the plastic trim that goes down the side of the windscreen O/S these seem impossible to find…Any ideas ?
LennyD said
Thanks for all your help guys…..i think i will have no problem removing all theses parts its just the servo i am not sure about……Would i be better getting someone that knows there onions to do this ???
The A pillar trims arent made anymore and a nightmare to get hold off.
I got the garage to remove and refit my servo as its a fair job.
![p12aac in the usergroup ‘Local’ p12aac in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
6mm or 8mm inside diameter ??
Also I'm sure you can use Vw Golf mk3 washer hose.
Some how. Hope I can get it half as good as yours
P12… Yes please post pictures then i can see if I am going in the right direction …. When you say caliper holders … What do you mean?? The top 2 rad brackets ?
