Clipper back window
(In Topic #186585)
![Avatar](https://fbcdn-profile-a.akamaihd.net/hprofile-ak-xap1/t1.0-1/p50x50/10380299_10152133647411239_4246548641506368300_t.jpg)
![Amy Williams in the usergroup ‘Regular’ Amy Williams in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I've just bought a 89 vw clipper cab, it doesn't have a back window in the roof. Can you buy a window to put in or does it need a new roof?
![snoopin in the usergroup ‘Local’ snoopin in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1620504746.jpg)
![chortle in the usergroup ‘Local hero’ chortle in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Welcome to the Club.
the rear window bottom section is held in place by 2 brackets that bolt to the frame and the parcel shelf supports.
If there missing you'll need them.
Plus the top section is held in place by 2 webbing straps and dowel pins.
If the webbing straps are missing then it's top off time as the fixings are underneath the whole lot.
(See piccy at the bottom, you'll see the Frame with the 2 webbing straps)
It's a common scenario as the rear window frame rusts out folks don't bother to replace them.
The frame is made up of 4 sections
The metal frame (usually Rusts away)
The insert (the hood material is stapled here)
The rubber seal (speaks for it's self)
The glass (like wise)
You'd need to check what you have left as to the above.
Chortle
You need the longer thinner brackets shown.
![](https://i380.photobucket.com/albums/oo248/chortlemk1/949665F1-2721-4094-93DB-299E36026E14-1144-0000034FEC54F66C.jpg)
![](https://i380.photobucket.com/albums/oo248/chortlemk1/hoodfame2.jpg)
Pictures of window frame with out the roof.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1417325/CIMG4723.jpg)
You can just see the end of the webbing which hold the top of the window frame in this picture
![](https://vwgolfmk1.org.uk/uploads/pbextract/1417325/CIMG4721.jpg)
New roof without window hole cut
![](https://vwgolfmk1.org.uk/uploads/pbextract/1417325/CIMG4728.jpg)
Cut here.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1417325/CIMG4737.jpg)
Then left with this befor seal and glass goes in
![](https://vwgolfmk1.org.uk/uploads/pbextract/1417325/CIMG4740.jpg)
You just need to go see what you have left on the car and get back to us.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/5golf.jpg)
![jayc in the usergroup ‘Local’ jayc in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I've looked in the car, I have no brackets so will need it all! how much roughly does a window cost?
![](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cool_flare.png)
Brackets here if hibbs doesn't have any however ask for the fixing bolts too.
