1.5 to 16v fuel pump wiring?
(In Topic #186523)
![jetjim in the usergroup ‘Local’ jetjim in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Car was originally a 1.5 but had a mk2 1.6 carb fitted when I got it. I've now fitted a kr on bike carbs (full conversion from another mk1) but am stuck when it comes to wiring up the fuel pump/pumps.
I have the in line pump he was using (was mounted in the spare wheel well) and have a gti sender. The sender has a 3 pin connection where my original is 2 pin and how do I go about powering the in line pump?
Hope this makes sense
i would power them both from a kjet fuel relay for safety, what fusebox is it early ceramic or later blade?
since its later fusebox its pretty easy, fit the kjet relay in the factory spot and either add a wire to e/14 (needs large size round pin) or add a 9.53mm spade (standard size, available all over) to N with an inline fuse. you want one without a rev limiter I'd assume, GSF sell them part number 935VG0090
E/14 is fed from the fuel pump fuse, but N is not hence the inline fuse
edit: this will help with the fusebox wiring:
http://www.clubgti.com/showthread.php?219775
Shall let you know how I get on
