1983 Mk1 TinTop 2.0 16v ABF
(In Topic #186431)
![Avatar](https://fbcdn-profile-a.akamaihd.net/hprofile-ak-frc1/t1.0-1/c8.0.50.50/p50x50/485581_10151835555966301_734711351_s.jpg)
![PostDestruction in the usergroup ‘Newbie’ PostDestruction in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Full Leather Interior
Spec/Trim option:
Year of manufacture: 1983
Mileage: Shell: 160000 Engine: Recently Rebuilt
Price: £3750
Contact details: 07886092010 post_destruction@hotmail.com
Condition: Excellent
Service history: Lots of Receipts
Mot expiry Date: January 2015
Taxed or sorn: Taxed
Description:
PRICE REDUCED TO £3500 - GEAR LINKAGE NOW SET UP BY THE PHIRM!
- 15 x 7J ATS Cups in excellent condition, no curbing, no dings, no laqueur peel. Wrapped in Toyo Proxes T1R's with less than 500 miles use.
- Fully rebuilt top end and bottom end
- Lightened and balanced crank, rods, pistons, flywheel etc
- Upgraded valve springs
- Black diamond uprated clutch and bearing
- Reconditioned gearbox.
- Recon shell 4 years ago.
- Newman high lift camshafts & adjustable vernier pulley - Will come with original cams as these may be preferable for daily driving.
- Remapped, all set up on the dyno by TSR Performance in Somerset.
- K&N 57i kit,
- TSR Performance gear linkage set up and new bush's and selectors - This requires some fettling as first is tricky.
- Full red leather interior, seats, door cards, rear shelf, everything!
- Spax front and rear adjustable suspension
- Full straight through Milltek stainless exhaust system
- Gas flowed cylinder head, ported and polished inlet manifold and throttle body.
- New starter motor, water pump, radiator, timing belt and aux belt
- New crystal head lights and bulbs with upgraded wiring loom. Will come with xenon light kit which just needs fitting (brand new in box)
- Has ABF alternator as is more reliable. New battery, every gasket and seal is new,
- Just been serviced including new HT leads and plugs, Samco hoses, strut brace
- Rear disc conversion, new EBC drilled and grooved front and rear discs with green stuff pads, new rear brake callipers new hand brake cables with 16v master cylinder and servo.
- Original shell was involved on a very minor ding so unfortunately has a cat D. It only had a dented wing and door which have both been replaced and resprayed.
Contact details at the top, please phone, text or email with any questions. My name is Philip.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1416151/IMG_2954_zps3814ec98.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1416151/IMG_2958_zpsd4edecad.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1416151/IMG_2959_zpsb31f670a.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1416151/IMG_2960_zps8b9e90f9.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1416151/IMG_2961_zpsbed6916b.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1416151/IMG_2962_zpsf9c3c2ee.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1416151/IMG_2963_zpscd525901.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1416151/IMG_2964_zps383a4788.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1416151/IMG_2966_zps0b9991a2.jpg)
