Please Help Parts Needed for GTI Campaign
(In Topic #183738)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/9avatar.jpg)
![cornishman in the usergroup ‘Paid Member’ cornishman in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![cornishman in the usergroup ‘Regular’ cornishman in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Front "GTI" badge
Rear "Golf GTI" badge
Full set of Decals
Trim clips
Tailgate rubbers (part no. 171971840)
Campaign leather steering wheel
Golf ball 5 speed gear knob
Cigarette lighter
Bulkhead rubber drain (part no. 17181819419)
I think that's it for now, I'm sure I'll think of something else though.
Thanks,
Trevor.
Last edit: by cornishman
But as above, look in the shop. Classic-Vw.co.uk or click the link in my sig
I'm redoing it at the moment. However the search button works wonders
Cigarette lighter
Any help would be greatly appreciated.
Thanks.
![cbdubs in the usergroup ‘Local’ cbdubs in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Climbatize in the usergroup ‘Local’ Climbatize in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
MK1 Golf 4x4 Build
MK1 Golf 4X4 | Facebook
![tubbett in the usergroup ‘Paid Member’ tubbett in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![tubbett in the usergroup ‘Old timer’ tubbett in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Pm if you like bud (i am away at work at the moment so cant send it straight away)
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
RichardHall said
What are the top dash trims that you are after, if you mean the four/five rounded rectangular cut outs in the dash right next to the windscreen then I don't think these were a standard item for the Campaign, mine does not have any trim round the vents and I know mine is as it left the factory.
Hi Richard, The vinyl around those vents tends to come away from inside (its only glued in) and a repair was made available consisting of little plastic pieces matched to the holes of the dash which when pressed into the hole stops the vinyl peeling back over the holes and blocking air flow
Mr cornishman, the vents are readily available from crazyquiffs, they are also almost always on ebay so that should be an easy one to cross off the list
Thanks,
Trevor.
Thanks.
