Help and Advice PLEASE!
(In Topic #185068)
It's hard to advise without knowing for example, are you just cleaning parts in preparation for paint or cutting pieces out etc… and welding in new ones.
If the last applies, is it just panel pieces or chassis members maybe?
See what I mean!
Good luck and the best advice I can give you is one take your time.
Two think twice before you turn the machine on!
It makes a lot of mess and they don't last long but I've not used anything better - you need a 4.5 inch grinder to use them on.
If you're doing the rear wing then you'll need grinding and cutting discs for the grinder, then of course all the MIG welding gear to fit the new one.
Where in Cambs are you?
Hope that helps
Hairyarse said
For removing paint and not grinding metal away, these are excellent! - http://www.ebay.co.uk/itm/111029769381
Hope that helps
what grinder do these fit please? a link from ebay?
Got mine from Homebase for about 30-odd quid each
Caddylove said
Thank you that's very kind of you!
No problem, just hollar
