Mk1 Golf van with Jetta front end. 1.6TD £1800
Mk1 Golf van for sale.
Now on Ebay.  161296651873
This is your chance to own a totally solid 1981  Mk1 Golf van!
£1800
Northamptonshire.
Mk1 golf van with Jetta front end.
1.6 TD engine.
Coilovers.
2” engine and front suspension raise.
Gti vented discs on front.
No welding needed.
Interior and engine wiring need finishing.
Dry stored.
A lot of work has been put in to the shell to make it totally solid and rot free.  No more welding required.
The engine is a 1.6 TD from a Mk2.  It came from a running car that was scrapped for rust issues.
Has the following new- starter motor, cam belt and roller, oil cooler and filter, rocker gasket.
The complete wishbone assembly has been raised 2” for clearance.  The engine and box have also been raised so the sump isn’t on the floor.  The steering rack has been raised and the front of the tunnel clearance for the exhaust.
Work required-  Interior needs finishing.  The carpet, door trims and headlining aren’t included.
The engine needs wiring.  I think all wiring needed is included.
Brakes need bleeding.
Exhaust will be included and needs fitting.
Also needs an air filter and could do with an intercooler.  I have an intercooler which will be included.
Paint needs polishing.
A couple of linkages from the 5 speed box are also missing.
I have the V5 in my name, shown as a 1.6 Diesel.  Currently SORNed.
Last edit: by jopro
Please add a location as per the rules
Ade
