My first car & project, Mars red 1.1 1982 mk1 golf C
30,000 miles on clock and 3 past owners
'83 formel e
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
Everything is working fine on the car apart from sometimes when driving I will loose all revs when accelerating then the engine will cut off after about 5 seconds. I thought I had solved this same problem when I first got the car on the road, but it turns out I was just leaving the choke on for too long (I was told leave it on till the engine is up to temperature) which was flooding the engine which would also explain why it took quite some time to get it going again. So by changing how I use the choke fixed this problem up until now.
My problem now is that it has happened twice now and in totally different situation, where as before it will happen everytime after 5 - 10 minutes of driving. Its the same problem as before where ill be driving along then go to accelerate and it will rev up to about 1cm of movement on the pedal then not accelerate at all past that point then the engine will die. Both times this has happened I've got out and inspected the engine and all is visably fine, I give everything a wiggle and a look over both when not running and running. When trying to start it back up it will take a fair few attempts with slight pedal pumping once I hear the engine kick into life. But the really confusing part is that the car is fine once it has happened? as in it does'nt happen again for the rest of the day and all is well.
So my question is why? has it happened to anyone else? and what the fix is somebody knows? Thanks in advance for your time.
I'm no expert with mechanics but could your issues be something to do with the fuel? Muck in the tank or something? As it has been sat a while, they can get rust and dirt in there.
Last edit: by golf1980
What did you use to clean it under the bonnet? it came up really well.
My New Year's resolutions are: 1. Stop making lists. B. Be more consistent. 7. Learn to count.
What a clean up! Really good job there. The engine bay is a complete transformation as well!
As for your running issues, to be honest it could be a number of different things. They all tend to have their own little oddities.
A common problem a lot of people find is that the filler neck rusts (especially when stood) and flakes of rusty cr*p fall into the tank which then get sucked through the fuel lines and get stuck in filters etc. I'd have a look at this first of all as it is easy to check.
Apologies, I skim read bits as well, what carb are you using?
Joe
1992 Pearl Green Clipper Cab - 16v (9a block, KR head, GSXR600 Carbs)
Desperado said
Great job on the clean up and that's a brilliant first car.
Thanks! Its a shame I didnt save this really detailed message i sent to somebody, listing exactly how i cleaned the engine bay. But it basically involved: Covering the engine with plastic sheets then gave everything under the bonnet a good blasting with the karcher, once all the surface dirt came off we switched to the foaming nozzle on it filled with degreasnt and sprayed it all over. We let it sit for a couple of minutes then got to work with various sizes of hard brushes all-over then just blasted it back off with the normal nozzle. We repeated this 3 times. As for the engine i have only fitted new parts here and there, cleaned the air filter also did some cable management. Then of course sprayed the rusty metal work. Hope this helps
Ice2812 said
Very tidy……
Why thank you
Thanks pal, my comment to Desperado should answer your question
JoeHayes said
Hi mate,
Joe
Thanks Joe
I've had my head under the wheel arch and all is good for the filler neck, Looks and feels solid top to bottom. I've flush the fuel tank out completely and blasted the fuel lines through. Its also had all new fuel hosing and fuel filter which is just about completely clean (only a few tiny parts in it) and off top of my head its a solex 34 pict 7.
Haven't been on my thread in a while, its crazy to see the photos at the begin of my thread to how it is now. My plans haven't changed for it by restoring it and keep it stock but in the future I'm going to go to the other end of the scale and get a GTI so that one can be my toy, big engine, wheels, lowered ect ect Here's a photo I took this afternoon after cleaning it to get all the horrible salty dirt off her, was a nice supprise to see the sun aswell.
Last edit: by ImJakeP
Where are you based? Would love to see this at a local show.
why not enter it in the next Car of the Month when entries start?
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
Much appreciated
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
