Help my new BBS RM's are leaking through the rims ??
(In Topic #183613)
i have just bought re-manufactured RM's and when I got the tyres on today they leaked through the Rims !!!!
What do I do to sort this ??
All advice greatly appreciated :-)
Chris
Last edit: by Massbad69
Premium Yam Yam
I think you might have to spilt them and reseal also check the bolts have been tightened to correct torque setting,but I'm sure a BBS guru will be along to put you right
Last edit: by Swerve
83 Candy White Campaign http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmk1-golf-restoration_2 89 Caddy pick up http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-other-cars-and_2%2Fcaddy-barn-find Mk1 Scirocco project completed
Yes I've now realised its not the bolts it's the rims obviously.
I was wondering if a bead if tiger seal right round the inside bead would be good enough ??
The existing bead looks best and precise but poss hasn't gone off correctly ??
I don't want to split them as I would rather send them back !!
I've got the correct sealant coming from a supplier up here in a weeks time when they get more stock in.
Then I will remove any redundant sealant and clean and sand the area, then put the new sealant on and leave it for a day at least.
Then get the tyre fitter back and try again :-/
1.8T CABBY
1.8T CABBY
Marketing Manager
Flipped the wheel around and put another 6mm bead between the lip and the barrel. Leave to cure overnight and then fit tyres. Had the tyres fitted on the car for 3 months and they haven't gone flat. Used a £3 tube of evostik sealant which did 2 wheels easily.
Doing the other 2 tomorrow so if needs be i can provide a step by step pictoral guide for you?
1973 BMW 3.0CS "Helga"
1981 VW Golf GTi "Agolf"
1986 Ford Escort RS Turbo S2
1987 BMW M535i - 'Klaus'
Instagram: @ahmet_e9
I'm on hols just now and I have ordered the sealant which should arrive after I get back this weekend.
Marketing Manager
Hope that helps fella
The guy that's rebuilt mine has just not put any silicone around the rim on the underside.
So I will run a bead around and then smooth it with my finger.
I then hope that's enough to hold the air.
Thanks a lot for your help.
Cheers Chris
Marketing Manager
