Shellby - 83 gti ABF on carbs
Thanks AndyHairyarse said
Yep those wheels are going to look the nuts Matt![]()
Last edit: by pazwaa
Melteddrummer said
Defo need some rubber in that turret, can't be metal on metal surely? could be wrong though bud![]()
Agreed!
I've got the rubber bushes, will give it a try. Gonna ring avo too, see if they can advise.
Does the rubber bush go above the aluminium one on the strut? The sleeve? Does that go through the bushes at the top?
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fvwtech.no-ip.info%2Fimages%2Fgolf%2Fg1rearsusp.jpg)
fit bush 40 on top of the spring plate, fit sleeve 35 and tighten the nut 39. then fit the shock to the car and fit the rest of the bits
I take it 34 gets binned because i use the one on the strut (spring plate)?
The sleeve 35 goes through bush 40, then nut 39, then bush 41? so the sleeve doesnt go through bush 41?
Bit confused
then you fit the shock to the car, bush 41 goes on top of the shock tower, followed by all the parts above it in the diagram to secure the shock to the car
rubjonny said
yes bush, sleeve then nut. tbh you could put sleeve and nut on first as the bush just pushes over the sleeve.
:thumbs
Can you buy it still?
That said it would be very simple to make. If no part code appears ill measure it up and make some Andy, will knock a couple up.
pazwaa said
So far I've only found one of the sleeves in my bag of bits, no idea where the other has gone![]()
That would be 'awesome' - as my lad says!
rubjonny said
part 35 is 171512117, but NLA unfortunatly. mk2 ones will fit the shaft fit but not sure if they're the right length
Thanks John!!
http://www.vwheritage.com/vw_spares_Spacer-Sleeve-Rear-Shock-Golf-Jetta-Mk2-191512117_act_shop.product_pID_127440040.htm
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/103image.jpg)
![olethalb in the usergroup ‘Old timer’ olethalb in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
olethalb said
mk3 / 4 / 5 polos all have them too, think they are a touch longer from memory so could trim them?
Cheers Olly
![](https://vwgolfmk1.org.uk/uploads/pbextract/1401049/F69A40E3-3853-408D-AD5A-8F6F47448DE4.jpg)
After half an hour of routing i found it, even managed to fit it
![](https://vwgolfmk1.org.uk/uploads/pbextract/1401049/BFD405AD-022B-49DF-90F6-2C3A416EC3BF.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1401049/CEA074B6-7983-4834-94B4-BC26A4E1EEB4.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1401049/D2DF0FE6-756A-4C32-81CE-353A97D95454.jpg)
But as i was torquing the 6 bolts up, the clutch didnt rotate, seems the engine is siezed
I took the big end bearings off to get the pistons out to redo the piston rings, could i have put it back together wrong? should i change the crank bearings and shell bearings? Andy also suggested getting the crank checked.
Any advice would be greatly apprieciated.
Mstt
On the plus side though the state of your garage made me laugh 'cos I thought mine was untidy
