VW Golf MK1 Cabby 16v Conversion - poor / lumpy idle
(In Topic #182011)
![Dessie66 in the usergroup ‘Local’ Dessie66 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Starting is no problem, but the idle is irrational and bumpy. I took the vehicle eventually to my local VW garage and to be honest after 6 months have said it's the wiring to the ICV. I checked this out on the site and got the wiring diagram and a new 244 relay, but this has dumb founded them. Per the wiring diagram, it looks as though the Mk2 ICV and relay only has to connect via 3 or 4 wires, the rest being redundant, on the Mk1 wiring loom. Is this correct?????
Also, per chance anyone on here know a VW specialist or auto electrician on Mallorca. It's killing me having no car :-(
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=25972
Do I still need to connect up ALL the wires from the 244 relay?
You help is very much appreciated
Des
i suppose you could leave the over-run cut-off valve off but thats only 1 less wire so you may as well have that working too!
have a look in my sig, g2krecuce1.pdf its all in there, nothign to it
thank you very much indeed
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/K19OLF%20Avatar.jpg)
![Craigt in the usergroup ‘Paid Member’ Craigt in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Craigt in the usergroup ‘Old timer’ Craigt in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
