Shellby - 83 gti ABF on carbs
there is a separate metal cup that sits over the bolts for rear discs, though often missing
![pazwaa in the usergroup ‘Old timer’ pazwaa in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
It did come as a kit. So basically I've got it the wrong way round, needs inserting into the disc?
Have to check but don't think I got the metal spacer.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/9image.jpg)
![Massbad69 in the usergroup ‘Local hero’ Massbad69 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Great build and keep the updates coming
![:cool:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cool.png)
http://www.vwheritage.com/vw_spares_Cover-Stub-Axle-Golf-Mk2-83-92-Scirocco-83-92-191501639A_act_shop.product_pID_155248192.htm
rubjonny said
if you wanted them part number is 191501639A, 3.67+VAT from VW or if you cant be bothered to drive there:
You are a bonafide hero, john, thanks
Massbad69 said
Just read through your full thread again and its epic and I wish I had your skills![]()
Great build and keep the updates coming![]()
Thank you sir, much appreciated
Not sure about my skills. I started working life as a welder, which helps. But welding cars is a black arts, so thin metal, very easy to blow holes
![:P](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cheeky.png)
Been in engineering all my working life, so used to build things and working around problems. Also lucky to know someone with a workshop I can use, albeit a medieval barn, but has everything needed to restore a car.
Be a different story when it comes to engines and wiring, I will not have a clue
![](https://vwgolfmk1.org.uk/uploads/pbextract/1393867/87A35E86-DFA6-4993-9CB7-F05D36982FC9.jpg)
Greased the shaft
![](https://vwgolfmk1.org.uk/uploads/pbextract/1393867/B7347808-B710-44D2-A47B-A13C0ABB288C.jpg)
Disc on
![](https://vwgolfmk1.org.uk/uploads/pbextract/1393867/58737478-9E56-4688-B990-0C9892C4D400.jpg)
Use an M12 repair washer on top of the bearing
![](https://vwgolfmk1.org.uk/uploads/pbextract/1393867/3293C265-4041-402F-9341-640975336B86.jpg)
Tighthened the nut to "just nipped", then backed it off to allow the disc to spin freely. Then add the nut cover, turn the nut till the little splines on the nut cover line up with the hole through the shaft
![](https://vwgolfmk1.org.uk/uploads/pbextract/1393867/6772D147-88CD-4607-9A9A-B79CEDE4754F.jpg)
Split pin in
![](https://vwgolfmk1.org.uk/uploads/pbextract/1393867/7B4C6D66-DFC4-47E8-899B-ABA14968129F.jpg)
Then put the remainder of the grease in the bolt cap
![](https://vwgolfmk1.org.uk/uploads/pbextract/1393867/6DDCE9F7-4900-4FC9-B072-F9FD9F98BAF7.jpg)
Cap fitted. These were a pita to get on, very tight. ended up just bashing them with a hammer till they complied
![](https://vwgolfmk1.org.uk/uploads/pbextract/1393867/C2A68BB1-5C46-4D70-85D5-E02AD3886FEF.jpg)
Cleaned the carrier threads out with a tap. Paint in the holes is enough to stop the fixings going in.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1393867/9D1827B1-B904-4148-8EA0-5307E22C574C.jpg)
The fixings I had were a tad too long, so cut them down with the grinder. Tip - if you do this, put the nut on first, then after cutting, the nut will reform the thread as you wind it off
![](https://vwgolfmk1.org.uk/uploads/pbextract/1393867/1E32940B-EE0C-49CD-9AFF-68ADD30FAB0C.jpg)
Carriers and adapter fitted
![](https://vwgolfmk1.org.uk/uploads/pbextract/1393867/56CEA129-01A4-483A-8DE9-82287DF49BB2.jpg)
Wheel studs fitted - overlong to cut down later
![](https://vwgolfmk1.org.uk/uploads/pbextract/1393867/6B52A6D7-64EA-42CF-9C42-AE5C73FEFA3A.jpg)
And alloy trial fitted
![](https://vwgolfmk1.org.uk/uploads/pbextract/1393867/126C5BB9-00C2-44AC-B035-6D4D61874833.jpg)
Another day done!
Need to re-assemble the calipers, and trial fit the whole back suspension, make sure the alloy fits. Hopefully be done next week.
Thanks for reading, any comments, send em
Last edit: by pazwaa
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/greenman.jpg)
![borednow in the usergroup ‘Moderators’ borednow in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![borednow in the usergroup ‘Regional Hosts’ borednow in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![borednow in the usergroup ‘Local hero’ borednow in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Brembo……hmmmmmmmm
Have you sorted the front wheels yet? As suggested a bit of arch rolling would help. Maybe a little bit of stretch on the tyres too. This'll help get em tucked just a tad.
Keep it going mate
Ian
My bodywork friend said he can roll (actually hammer!) the inside arches, which will help. Think the tuck id imagined (after looking at far too many show cars and cars on air
Roll on next Tuesday!!
You can hire an arch roller of ebay. I have and it worked fine. Patience and time and more patience.
I tried rolling with a hammer on the golf. didn't work too well. I blame the rust though not my terrible skills
![O_o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blink.gif)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/008_zpse29681e9.jpg)
![Melteddrummer in the usergroup ‘Moderators’ Melteddrummer in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Melteddrummer in the usergroup ‘Paid Member’ Melteddrummer in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Melteddrummer in the usergroup ‘Local hero’ Melteddrummer in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![:wub:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/wub.png)
Keep the updates coming bud!!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Can't take my eyes off your wheels, so good
borednow said
As long as he's gentle it can work.
I tried rolling with a hammer on the golf. didn't work too well. I blame the rust though not my terrible skills![]()
Definately the rust
I tried knocking the inner arch in with a hammer many months ago, but it just seemed to spring back, so gave up! Chris tried it, and he made it look easy, and no deformation of the arch curve - guess it's just a case of having the knack
Melteddrummer said
Nice work on the build up Matt, I've said it before but I love those wheels![]()
Hairyarse said
Good work Matt, nice to get progress and know what you mean when you have hours of work and feel like you've done nothing!
Can't take my eyes off your wheels, so good![]()
Thank you Andy's. The wheels were a great find, completely by chance, right place right time
First fit the rear axle
Suspension strut first
![](https://vwgolfmk1.org.uk/uploads/pbextract/1396221/79373962-37EA-4326-9FD9-3B82AB13A883.jpg)
Beam positioned locally
![](https://vwgolfmk1.org.uk/uploads/pbextract/1396221/6A9B7A55-0F63-4066-A619-825D57349551.jpg)
Then fitted
![](https://vwgolfmk1.org.uk/uploads/pbextract/1396221/844B014B-D2AA-41C0-8C18-29CAB9EAF373.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1396221/6FC78B1A-9569-4645-9CAD-CC32B70A0D33.jpg)
Then alloy fitted
![](https://vwgolfmk1.org.uk/uploads/pbextract/1396221/6551DC02-A8A9-497E-8B43-0D821C95ECAA.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1396221/2A96DC05-26E4-4A63-937E-30F23CF207CB.jpg)
The edge of the alloy is about 20mm outside the rear arch, but I have the wheel packed out 10mm, and im going to face mount the alloys, which loses another 10mm, so hopefully should sit very nicely
The top of the rear strut has an aluminium bush
![](https://vwgolfmk1.org.uk/uploads/pbextract/1396221/1C6B9D6A-670A-4A40-8417-49D51ABFD389.jpg)
does this replace the rubber bush and just sit in the rear tower like so?
![](https://vwgolfmk1.org.uk/uploads/pbextract/1396221/DFC52B19-D33E-490D-B47F-6B874F97137C.jpg)
Then inside the car you have a bush and a cup washer like so?
![](https://vwgolfmk1.org.uk/uploads/pbextract/1396221/69579D14-DBEB-46A8-A9B8-E664CDC3E473.jpg)
Matt
![chipster2407 in the usergroup ‘Old timer’ chipster2407 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Looking good mate keep up the work
chipster2407 said
Wen i fitted my rear beam last week i wudnt of been able to do it without my old man, i found that if u slide a jack under the center of it and jack it up it makes it abit easier
Looking good mate keep up the work![]()
chipster2407 said
Also mate if i remember wen i fitted my coilovers u put the rubber bush ontop of that alluminium top mount, and also from the photo the cup washer u have is upaide down wen fitted it cups upwards
Cheers Chipster
Thanks for the suspension advice, will amend the way I refit it
