Mark 1 cabby manual roof to electric?
(In Topic #182446)
![Avatar](https://fbcdn-profile-a.akamaihd.net/hprofile-ak-prn1/573216_600875947_1592336587_q.jpg)
![Austin Line in the usergroup ‘Local’ Austin Line in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Has any here done this?
I have got hold of rams and pump looks like brackets are needed to be Welded . And of course wiring loom switch .
Looked through posts but couldn't find any info.
thanks in advance
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/144image.jpg)
![Julesgreycab in the usergroup ‘Old timer’ Julesgreycab in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
1985 Cabriolet GL
Julesgreycab said
Not sure how hard it is but I've got an electric frame that had the rams removed to make it manual if you are interested? It has a blue vinyl hood and white inner, rear windscreen too.
Yes I sure am can you email me or pm please ozzieboy@hotmail.com
It's the roof in good condition with no rips etc
power roof isnt an easy job by any stretch of the imagination, for a start you need to chop the ram brackets out of a donor car and weld them into yours
rubjonny said
sounds like your roof rams are weak or missing, either that or tyou have bent parts on the frame and/or siezed joints. it shouldn't be much effort to lift a hood when all is well, easily doable by yourself.
Thanks for the reply John, I have looked between the roof lining and outer skin around the rear quarter area and can Not see any rams ! I'm guessing that's where they would be located?
This would explain why it's such bloody hard work
some piccies in here:
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Fbodywork-fittings-and_2%2Fwhere-should-these-soft#post_1390927
