Rallye
I think the top one is 611 as not many people write a nine with a tail like that, could be wrong though. As for the pic below, I think it's a 50 with an initial too. Are both pics the same gear? to the left of the pic in the top pic there is a similar initial to the bottom pic, is there not?
Hairyarse said
I would agree 50 and initials, can you check with supplier or are they not the ones that marked it?
Or can you make the measurement or is that a daft question??
These units are etched at the time they are lapped together on a machine. They must take this measurement at the point when they lap it so in answer to your question I would say its impossible to measure and these were probably made 20 years ago so impossible to ask a supplier. I do know the company that made the gears though.
If it is 611 then it makes it the right way up in relation to the other gear however it does then make it 09 not 50.
I've just come back from a trip to Southampton to see a guy who is selling a load of Rallye parts.
We told him our predicament and he said "I've got a transfer box under here!" :P
However when he pulled it from under his bench it was from a normal syncro not a Rallye. We've had it off him anyway as none of the shims are available to set the rallye one up up so we thought it might be worth a punt just for the shims.
I've stripped some of it down tonight and the one gear I've been able to read is also etched the "right way" as per our original so I'm currently edging towards a pairing number of 611 and 0.09 as the measurement. :|
Just had a thought about how they are shown in the manual. They are also shown the same as the original gear and the gear I picked up tonight.
Think i'm going to go with 0.09mm and hope its ok!
Spent the day setting up the transfer box……
As I don't have the mandrel they call for I improvised and measured the nose of both new and old pinion gears against the datum face they tell you to measure.
Measuring the pinion nose position using a DTI and the digital read out on the lathe.
With some solder I was able to test the position of the original  by assembling the unit and squashing the solder between the two faces of known dimensions and measuring the squashed solder with a micrometer then adding the pinion nose dimension and the OD/2 of the input shaft together.
It came within 0.05 mm of what it should have been so that proved that my unorthodox method would be ok to use for the new set.
All i had to do was to get a new piece of solder squashed by the new gears in the same way and the difference it measured less the "50" dimension would give me the dimension of the shim I required.
Luckily the shims that came out of the transfer box we picked up last night were just right when used with one of the originals.
It also told me that going for the "50" measurement would make more sense. Once I built it up it became apparent that I wouldn't be able to achieve the correct amount of backlash if I had gone with the "09" measurement.
Need to get some shims made up now but I think its heading in the right direction.
That's very scientific! Nice work  :cool:
I contacted Heritage in the week to see if they could supply another gear set that was easier to read the dimensions but they came back saying that classic in Germany said it was the last one so spent some more time measuring yesterday so I could make the correct thickness shims as they are also obsolete from VW :P ……
Then had to make a jig to support the box and socket so I could torque the nut back up to 350Nm. Was going to use this picture……….
Then found a better pic :thumbs: …….
I wanted to run it at speed on the jig to double check the pinion mesh and that the preloads on the bearings were not excessive as the set up instructions makes it rather tight with new bearings.
I filled it with oil and rigged up this and ran it for an hour on the bench…..
It gets warm but not hot which is what I would expect with the bearing loads. I then stripped it to see what marks showed up on the teeth.
The wear mark looks to be fairly in the middle of the teeth which should be about spot on. (the lighter grey mark)
Don't think I can do anymore now - just cross fingers!
Finished…..
Last edit: by Yomp
Yep second picture the best  :thumbs:
Great patience and attention to detail Graham - I think you have done more than enough to ensure the longevity of this  ;)
After spending several unsuccessful months trying to locate a complete RHS sill for the car we eventually have had to make one from scratch.
Using the LHS sill we got from Heritage we've managed to produce a replica opposite hand sill.
This has not been an easy task as although the sill looks parallel and straight, it has a slight curve along its length and tapers down to the front wing. There is also various folds and flanges to reproduce at each end.
We initially started with a flat 1mm sheet and had the 3 main angles put in on a bender. We then had to get the sill to curve using a blunt chisel in the folds onto a sandbag.
This then distorts the main faces of the sill as it tries to crumple them up. At that point I left the workshop and left it in the capable hands of the panel beater! :$  :lol:
Anyway pics;
rallye sill
pic showing curve against straight edge
Lower rear detail
Rear detail
Front bottomside detail
The shell goes for Soda blasting this week and then a coat of epoxy primer before coming back to have both sills welded on and the welding completed. We thought it best to do it this way so the primer can get into the areas that won;t be accessible once the sills are on.
More great work Graham.
you're right, first glance the sill looks simple but its not. Great work, you must love your panel heater  :thumbs:
Great skills Graham !!
Ade
Problem with him is because he;s good - he's always busy so its difficult to get him to do it.
He does a lot of work building the 3 wheeler morgan bodies.
The groove above my rear wheel arch wasn't aligned properly where a repair panel hadn't been aligned. My panel chap managed to sort it out with a cold chisel, clever man!!
Maybe one to leave to the professionals Andy?
I reckon Matt!
Graham - just keep him sweet then and take one for the team if you have to!  :lol:
^^ :lol:
Excellent work on the sill Graham. :cool:
Cheers guys. I'll pass your comments on to him.
Melteddrummer said
I went up there last week to have a look at them but the straight one is rotten and the bent one is…….er……..bent!
you could possibly make 1 out of the 2 but the amount he is asking plus the transport costs and time sort of makes it prohibitive. there's probably the odd part here and there which may be useful. theyve been sat there for over 10 years.
took this pic at the same place while I was there.
If I'd known you were coming, I'd have baked a cake! :lol:
You've got to be careful not to fall through the floor in that part of the yard, I was there when the snow was here and went through the floor with 1 leg!! :P
