Doing head gasket
(In Topic #170197)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/216image.jpg)
![87cab_bb in the usergroup ‘Paid Member’ 87cab_bb in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![87cab_bb in the usergroup ‘Local’ 87cab_bb in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Any tips along the way, any recommendations on jobs I should do aswel?
If there is alot of carbon build up or bits of gasket left on the top of the engine block when you take the head off get a bit of copper pipe and flaten the end with a hammer you can then use this to scrap the carbon off the block as the copper is soft and should not damge the surface of the block try not to get bits falling into the cyinders, stuff some clean cloth in there and clean out all the little bits which fall in.
Have you started this job yet?
edit: oh and if the head will be off for any length of time put a load of grease on the cylinder walls to protect them. it may be an idea to do this regardless unless the head will be going straight back on as its a bit wet out there at the moment!
if you have a 2e2 carb then you'll have to get coolant to it somehow, if its a weber then no need to worry just leave it off
if it has a weber then great, no need to worry carry on with it
VW might still sell the stud or put up a wanted ad as anyone replacing there cork rocker cover gasket will get new studs and will not need the old studs or buy a rubber gasket your self (they are better than the cork ones) and you get 8 new studs in the box (you need to check its comes with it)
I have been toying with the idea of taking the head out my self on my 1.6 diesel
but dont know where to start from….
You guys are legends man,….
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
![C:\fakepath\image.jpg C:\fakepath\image.jpg](https://i1345.photobucket.com/albums/p679/damonspowage/The%20Mk1%20Golf%20Owners%20Club/image_zps3331fe78.jpg)
![C:\fakepath\image.jpg C:\fakepath\image.jpg](https://i1345.photobucket.com/albums/p679/damonspowage/The%20Mk1%20Golf%20Owners%20Club/image_zps1b24f13a.jpg)
just make sure its not a 1.6 gti gasket as thats slightly different
rubjonny said
get yourself a brown haynes manual lad, everything you need to know is covered in there. if you keep your eyes open can get one off ebay for 99p
I 2nd that
I got mine for 0.99p plus postage
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
