Crankshaft pulley bolt removal
(In Topic #177276)
Help
Andy.
Trying to remember the stuff I used. JonP recommended it to me and it did the trick with anything I used it on such as rear beam bolts, manifold and rear suspension IIRC.
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.eurocarparts.com%2Fimages%2Fproducts%2F600x600%2F549774741.jpg)
Available from Eurocarpats.
Cheers bud
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/49image.jpg)
![jaybo in the usergroup ‘Local’ jaybo in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
2000 R1 TOY ;-)
2003 CIVIC TYPE R reliable daily
1989 cabby 1.8 gti ongoing project (my 1st vw)
husqvarna te 410 supermoto
just aquired a series 1 tintop
That should give you an idea of how tight it is.
I've just replaced the timing belt on my discovery and the front pulley on that was torqued to 300Nm. I had to use 6ft of tube over a 3/4" drive socket and bar to get that to shift. the other issue was stopping the engine turning whilst trying to undo it.
1/2" drive was too weak and just flexed.
jaybo said
get some heat on it,it will have been loctited in,then try again with a good quality impact gun.
Was thinking of heat but I wasn't sure if the heat transfer would damage anything else?
Yomp said
Whats the specified torque for it?
I read somewhere the torque is 160Nm I've got a 5' 3/4" drive breaker bar at work, might have to nick that but like you say, how do I stop it turning? the engine is in my engine stand, on wheels
Melteddrummer said
I read somewhere the torque is 160Nm I've got a 5' 3/4" drive breaker bar at work, might have to nick that but like you say, how do I stop it turning? the engine is in my engine stand, on wheelsI keep chasing it around the unit
If you still got the flywheel on it then screw a bolt in one of the clutch cover plate retaining threaded holes but leave it protruding. Put another m12 bolt in one of the block to gearbox mounting bolts again leave it long put one end of a 19mm / largish spanner on one bolt and the other end on the other bolt while turning the flywheel in an anti clock direction until the spanner gets jammed between the two bolts and that will lock the crank. You may have to lower the engine to the ground though.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1375393/l6.jpg)
Cheers dude!!
If you have and you are stripping the entire engine then take the head off before you turn the crank.
case of put it in a stand and get the largest lever you can find to crack it loose. have to have someone standign on your engine stand as well probably as it'll want to tip over!
personal experience with this helping a mate do his, i wasnt really heavy enough to act as a counterweight but we got there in the end
Yomp said
It's only a problem if you've removed the timing belt.
The belt has been off for ages but I've been careful to keep all the timing marks as they were. The cog behind the crankshaft pulley has previously been marked up as well.
If I have to move the crank to jam the timber in, can I just turn it back to the marks then remove the head?
rubjonny said
block o wood wedged in the crank better option, its that tight you'll probably bend/snap the bolt in the flywheel if you use the trick above!
Cheers for that John, now I come to think of it, I'm sure I did that with the DX engine.
Take the head off before stripping the bottom end if your fully stripping the engine anyway.
