What did you do to your MK1 today?
![shaunyp in the usergroup ‘Paid Member’ shaunyp in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![shaunyp in the usergroup ‘Local’ shaunyp in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_20130609_165358_zps201774ba.jpg)
![AndyParsons in the usergroup ‘Local’ AndyParsons in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
AndyParsons said
hi Andy, did you buy the flexi brake pipes or buy them and just fit them yourself, i need new flexi pipe and lines for my rear disc conversion.
![CraigSherriff in the usergroup ‘Paid Member’ CraigSherriff in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![CraigSherriff in the usergroup ‘Old timer’ CraigSherriff in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
1990 - Cabriolet GTI 1.8 (DX)
Ordered some new rear speakers and some upgraded speaker cable for the car
Replaced damaged and scratched instrument faces with better ones courtesy from another golfmk1 member! <~~ A complete ball ache getting the speedo to read right!!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/5702ccac3bbda.jpg)
![andyphill in the usergroup ‘Old timer’ andyphill in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Still trying to find where the water is coming into the rear passenger side of the boot.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/156image.jpg)
![pbenny0 in the usergroup ‘Local’ pbenny0 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Also had same problem of water getting into boot. Was the drain tubes from the sunroof being short and letting the water drip down the inside of the rear quarter panel.
See this post, maybe the same problem for your car.
Post Posted 22 October 2012, 1:28 AM Rating: #1233210 (In Topic #147350)
![Denia in the usergroup ‘Paid Member’ Denia in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Denia in the usergroup ‘Local’ Denia in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![:cool:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cool.png)
1992 Red 'Sportline' LHD from France now in Spain,
1991 White' Young Line' GTI LHD from Germany that I can not take to Spain because of Brexit!😒
![satans_creation in the usergroup ‘Old timer’ satans_creation in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Forumpic.jpg)
![Early-1800 in the usergroup ‘Paid Member’ Early-1800 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Early-1800 in the usergroup ‘Local hero’ Early-1800 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![](https://img.photobucket.com/albums/v620/early-1800/DSCF1309_zps1829a3a5.jpg)
Not quite 23 degrees Spain
![](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
![Avatar](https://i1099.photobucket.com/albums/g400/Pearcestu/bad48f7d-f423-46ef-8139-0695961c6e13_zps7e522994.jpg)
![pearcestu in the usergroup ‘Paid Member’ pearcestu in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![pearcestu in the usergroup ‘Old timer’ pearcestu in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
shaunyp said
Sorry for late reply bud. Bought it all off fleabay. ((5 of the stuff that was on there needed angle-grinding off! So I made up some replacement hard lines as I have the kit (cheap off ebay if you wanna go!), new flexis over the axle beam, hard lines to the mk4 rear caliper and new flexis to link these up.
Up front my brake upgrade uses Vectra front calipers, and some have used the VX flexis, but I found them too long and would foul the suspension. After a bit of research i found that Seat Arosa (so still VAG Group) ones were the correct length and had the correct end fittings.
Beam flexis were Mk1/T25 and rear flexis were from Passat.
All from ebay and reasonable cost, details below:
FRONT - Seat Arosa £15 pair, item no 131033460464.
MID - T25, tenner a pair, item no 221224204192.
REAR - Passat, £12.22 a pair, item no 131032789618.
You may also want new spring clips, my old ones were knackered, £2.85 for 4 from BandB, item no 370966344847.
The only additional thing you might want to do is secure the hard line to the rear beam near where the rear flexi joins (it'll make sense once it's all done), some use zip ties around the beam, i got hold of some 5mm rubber lined p clips and tapped a hold into the beam to hold it securely whilst looking a little less bodged.
Best of luck with conversion, mines now 80% there now, I'm just refurbing the suspension.
Replaced old air filter with new Bosch one. Replaced handbrake lever as my old one was damaged by previous owner(s) - Got this for a fantastic price of another user on here… Thank you
![](https://img100.imageshack.us/img100/1160/90by90.jpg)
& Then finally, after having to take the drill to the old completely rotten and damaged screw, fitted my new Chrome mirrors courtesy of CrazyQuiffs.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1372406/7C2C087B-4B09-4F6D-A740-D2AB1ADD4BCF_zpsuokkljoi.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![WeegieBob in the usergroup ‘Local’ WeegieBob in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Discovered they appear to be two different types of lamp - one with 'short' mounting lugs and the other with 'long' mounting lugs.
![O_o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blink.gif)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/mk1%20.jpg)
![jonjones91 in the usergroup ‘Local’ jonjones91 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
oh and spent nearly a weeks wages at vwheritage so will be selling a kidney to fund the rest of the car if anyones interested
