Advice Needed for Indicator issue
indicators not working
Hi All
I need some help.
my indicators have stopped working. the hazard flashers work ok, but the indicator light on the instrument cluster is always half illuminated, and when i try to use the indicators they dont flash but the light on the cluster lights up.
i have purchased a new hazard flasher switch and the problem remains.
any ideas what could be doing it?
Mk1 Clipper
www.pcperfect.co
Im in no way an expert, but i had problems with my indicators. Check all the relevant fuses are working, then check the wiring to the hazard switch, theres a little brown one that can often be a problem!
Flick r - Flickr: ErosUK's Photostream Insta g r a m - @MK1_TOBY
Thanks for advice.
Still playing up.
Will have another 'root' around and see if i have pulled any cables
thanks
Mk1 Clipper
www.pcperfect.co
Sounds like a bad earth issue, although I've had a faulty bulb give similar issue's. I've posted a 'pin out' wiring guide this morning which may help. Meanwhile, I should check the connections on your back lights, especially the earths. And check the earths near the steering column as well. Hope you get it sorted.
If you want the PSD Boot Sticker file, it's here: Boot Sticker
mine did that.
the single wire on the back of the hazard switch had come off.. plugged it back in again and all was well..  :)
1983 mars red gti
1984 mars red gti
1994 golf vr6 - gone but not forgotten
2005 mk5 gti family wagen
Might have covered this already, but recheck fuse 19, preferably with a multimeter.
Push hazard switch in half way, do they start working?
thanks for advice all.
im going to have a play tommoz to try and sort it.
Its Doing my Head IN  :P
Mk1 Clipper
www.pcperfect.co
This happens so often.
Richievr is spot on. There is a single wire to the hazard switch that is often pulled off when you pull the switch out of the dash, it drops down and shorts to the dash metalwork and then blows a fuse.
Worth disconnecting you battery before you go routing for it as almost certainly you will blow a fuse otherwise.
Ade
ok will do thanks for tip
Mk1 Clipper
www.pcperfect.co
like everyone has said check all your fuses 19 is the common one.
GTI Campaign Helios Blue, Going back Standard
GTI Campaign Schwartz Black shouldn't have sold
GTI Mk7 Performance pack Daily drive
Polo 1.4sel Sunset Orange The Wife's
Triumph Tiger
BINGO..
Many thanks all,yep it was a rotten fuse
Mk1 Clipper
www.pcperfect.co
woooooooo!!!!!  :)  fixed for cheap!!!!!!
1983 mars red gti
1984 mars red gti
