Couple of rebuild questions.....
(In Topic #166535)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20180414_164311.jpg)
![Spidermonkey84 in the usergroup ‘Paid Member’ Spidermonkey84 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Spidermonkey84 in the usergroup ‘Local’ Spidermonkey84 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I’m sure I’ve read somewhere that there is an easy upgrade for the wiper motor, possibly replacing the original MK1 motor with a MK2 Golf motor, is this right?
If so I want to change it before I put the wiper assembly back in under the scuttle panel. Is there also an upgrade for the rear wiper motor that I should be thinking about?
When re-fitting all the rubber door seals what type of sealant should I be using to refit them with, tigerseal, or something else?
'84 MK1 Golf - View topic: Humble Beginnings........... - VW Golf Mk1 Owners Club '99 MK4 Golf
Mk2 and mk3 wiper motor is an upgrade, I have one of each in my unit. Hopefully I can find the plug to match the mk2 (mk3 is still in the car ready for breaking)
the front wiper motor from mk2 fits and I'm pretty sure the rear motor will go as well? the plugs differ so chop those off the donor and you'll have to swap the wiper linkage and some brackets
I'll see if I can get a complete MK2 wiper unit then and see how I can modify it to fit.
Like you said I'll check costs and go from there I think, cheers for all your help guys!
