Quaife ATB Diff Problems
(In Topic #166024)
![mrbooG60 in the usergroup ‘Newbie’ mrbooG60 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Heavilly Modified Mk1 Cab
Going back to a standard gearbox might be an option as a test, what other diffs are on the market? its been yrs since ive had any interest in wanting to sort this and don't read the mags
Another thing I noticed on track whilst cornering hard was a lot screeching for the front wheels like one wheel wasn't keeping its rolling motion whilst on or off the gas, is that likely to be the diff creating yet another issue?
![plasticman in the usergroup ‘Regular’ plasticman in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Front end is 0.5 dgrees negative camber, wheel alignment is parallel, 2 degrees of castor and 1mm of positive bumpsteer, I tried various set ups and this seemed best but still get the car pulling like crazy at times.
I used to run wheel alignment at parallel -1.25 degrees camber with standard lower wishbone bushes and trackrod ends and never had this issue, at one pint I never had an antiroll bar and didn't fell much different with it (std roll bar now fitted).
